跳转到主内容
Kodak EasyShare M381 Button Replacement
你所需要的
  1. Kodak EasyShare M381 Button Replacement, Battery: 步骤 1 中的图像 1,2 Kodak EasyShare M381 Button Replacement, Battery: 步骤 1 中的图像 2,2
    • First, press in and slide forward the battery latch as indicated by the arrow.
  2. Kodak EasyShare M381 Button Replacement: 步骤 2 中的图像 1,1
    • Press down on battery until you hear a click and release it. Battery should easily slide out.
  3. Kodak EasyShare M381 Button Replacement, Back Panel Frame: 步骤 3 中的图像 1,3 Kodak EasyShare M381 Button Replacement, Back Panel Frame: 步骤 3 中的图像 2,3 Kodak EasyShare M381 Button Replacement, Back Panel Frame: 步骤 3 中的图像 3,3
    • Remove the 3.9 mm frame screws using a Phillips #00 screwdriver.
    • Using a magnetized surface to keep from losing screws may be very helpful.
  4. Kodak EasyShare M381 Button Replacement: 步骤 4 中的图像 1,2 Kodak EasyShare M381 Button Replacement: 步骤 4 中的图像 2,2
    • Using both hands, carefully pull the frame apart from the camera.
  5. Kodak EasyShare M381 Button Replacement, Button: 步骤 5 中的图像 1,1
    • Carefully pick up frame and push upward on buttons.
  6. Kodak EasyShare M381 Button Replacement: 步骤 6 中的图像 1,1
    • Clean and replace as needed.
    • A microfiber cloth, or any other type of electronic cloth may be used to clean them if desire.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 9
总计 257
