跳转到主内容
修复你的物品
维修的权力
商店
配件
没有特定配件。
  1. Place thumb firmly on battery cover. Slide thumb right, the cover should follow and pop up.
    • Place thumb firmly on battery cover.
    • Slide thumb right, the cover should follow and pop up.
  2. Place thumb on orange tab and pull back towards screen. The battery should pop up.
    • Place thumb on orange tab and pull back towards screen.
    • The battery should pop up.
    • Gently lift battery out.
  3. 跳过升级
    通过使用多合一工具包维修可以节省成本。
    购买 iPhone 维修工具套装
    跳过升级
    通过使用多合一工具包维修可以节省成本。
    购买 iPhone 维修工具套装
  4. Remove screws from along outer edge of casing. There are 6 screws in total. Righty tighty, lefty loosey!
    • Remove screws from along outer edge of casing.
    • There are 6 screws in total.
    • Righty tighty, lefty loosey!
  5. Gently lift off front and back casing. Gently lift off front and back casing. Gently lift off front and back casing.
    • Gently lift off front and back casing.
  6. Remove screws along side. Gently peel off side casing. Gently peel off side casing.
    • Remove screws along side.
    • Gently peel off side casing.
结论
Kyanna
于2014年03月13日注册
313 信誉积分
创作了3篇指南
团队
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 99
