当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Place thumb firmly on battery cover.
Slide thumb right, the cover should follow and pop up.
Place thumb on orange tab and pull back towards screen.
The battery should pop up.
Gently lift battery out.
Remove screws from along outer edge of casing.
There are 6 screws in total.
Righty tighty, lefty loosey!
Gently lift off front and back casing.
Remove screws along side.
Gently peel off side casing.
Open the battery door and identify the retaining pin.
Push retaining pin out with small tweezers.
Once pin is out halfway, close door to ensure no loose parts get lost.
Continue to pull out the remaining length of the pin.
Gently lift off door cover.
取消:我没有完成这个指南。
与3其他贡献者
于03/13/14注册
313 声望
创作了3篇指南
徽章: 6
+ 3更多徽章
NMSU-EASLEY-S14S1G2
5 名成员
创作了10篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 166
