跳转到主内容
修复你的物品
维修的权力
商店
配件
没有特定配件。
  1. Place thumb firmly on battery cover. Slide thumb right, the cover should follow and pop up.
    • Place thumb firmly on battery cover.
    • Slide thumb right, the cover should follow and pop up.
  2. Place thumb on orange tab and pull back towards screen. The battery should pop up.
    • Place thumb on orange tab and pull back towards screen.
    • The battery should pop up.
    • Gently lift battery out.
  3. Remove screws from along outer edge of casing. There are 6 screws in total. Righty tighty, lefty loosey!
    • Remove screws from along outer edge of casing.
    • There are 6 screws in total.
    • Righty tighty, lefty loosey!
  4. 跳过升级
    通过使用多合一工具包维修可以节省成本。
    购买 iPhone 维修工具套装
    跳过升级
    通过使用多合一工具包维修可以节省成本。
    购买 iPhone 维修工具套装
  5. Gently lift off front and back casing. Gently lift off front and back casing. Gently lift off front and back casing.
    • Gently lift off front and back casing.
  6. Remove screws along side. Gently peel off side casing. Gently peel off side casing.
    • Remove screws along side.
    • Gently peel off side casing.
  7. Open the battery door and identify the retaining pin. Push retaining pin out with small tweezers. Push retaining pin out with small tweezers.
    • Open the battery door and identify the retaining pin.
    • Push retaining pin out with small tweezers.
  8. Once pin is out halfway, close door to ensure no loose parts get lost. Continue to pull out the remaining length of the pin. Continue to pull out the remaining length of the pin.
    • Once pin is out halfway, close door to ensure no loose parts get lost.
    • Continue to pull out the remaining length of the pin.
  9. Gently lift off door cover. Gently lift off door cover.
    • Gently lift off door cover.
结论
Kyanna
于2014年03月13日注册
313 信誉积分
创作了3篇指南
团队
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 66
