跳转到主内容
Kodak EasyShare LS743 Removing LCD Replacement
你所需要的
  1. Kodak EasyShare LS743 Removing LCD Replacement, Battery: 步骤 1 中的图像 1,1
    • Using your fingernail, open the battery cover.
  2. Kodak EasyShare LS743 Removing LCD Replacement: 步骤 2 中的图像 1,1
    • Slide the orange latch sideways to eject the battery.
    • Remove the battery from the battery slot.
  3. Kodak EasyShare LS743 Removing LCD Replacement, Kodak EasyShare LS743 Camera Case Disassembly: 步骤 3 中的图像 1,3 Kodak EasyShare LS743 Removing LCD Replacement, Kodak EasyShare LS743 Camera Case Disassembly: 步骤 3 中的图像 2,3 Kodak EasyShare LS743 Removing LCD Replacement, Kodak EasyShare LS743 Camera Case Disassembly: 步骤 3 中的图像 3,3
    • Using a Phillips #00 screwdriver, remove two 5.39 mm screws next to the battery slot.
    • Remove the metal piece holding down the lanyard, then remove the lanyard.
  4. Kodak EasyShare LS743 Removing LCD Replacement: 步骤 4 中的图像 1,3 Kodak EasyShare LS743 Removing LCD Replacement: 步骤 4 中的图像 2,3 Kodak EasyShare LS743 Removing LCD Replacement: 步骤 4 中的图像 3,3
    • Using a Phillips #00 screwdriver, remove seven screws located on the outside case of the camera.
    • One 6.25 mm screw is located on the top right corner, right to the "OK" button.
    • Four 4.45 mm screws are on the bottom of the camera.
    • Two 2.95 mm screws are on the left side of the camera, above the USB port.
  5. Kodak EasyShare LS743 Removing LCD Replacement: 步骤 5 中的图像 1,2 Kodak EasyShare LS743 Removing LCD Replacement: 步骤 5 中的图像 2,2
    • Carefully remove the rear camera casing.
    • Carefully remove the front camera casing.
  6. Kodak EasyShare LS743 Removing LCD Replacement, Removing LCD: 步骤 6 中的图像 1,3 Kodak EasyShare LS743 Removing LCD Replacement, Removing LCD: 步骤 6 中的图像 2,3 Kodak EasyShare LS743 Removing LCD Replacement, Removing LCD: 步骤 6 中的图像 3,3
    • Flip up the LCD screen to reveal the two orange ribbon cables.
    • Disconnect the two ribbons cables from their sockets on the motherboard.
结论
另外一个人完成了本指南。
团队
Cal Poly, Team 2-8, Johann Summer 2010 Cal Poly, Team 2-8, Johann Summer 2010 的会员
CPSU-JOHANN-R10S2G8
5 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 1,241
