本指南有最近更改,您可查看未经巡查的最新版本。
简介
This will teach you how to remove the lens.
你所需要的
Using a Phillips #00 screwdriver, remove two 5.39 mm screws next to the battery slot.
Remove the metal piece holding down the lanyard, then remove the lanyard.
Using a Phillips #00 screwdriver, remove seven screws located on the outside case of the camera.
One 6.25 mm screw is located on the top right corner, right to the "OK" button.
Four 4.45 mm screws are on the bottom of the camera.
Two 2.95 mm screws are on the left side of the camera, above the USB port.
Flip up the LCD screen to reveal the two orange ribbon cables.
Disconnect the two ribbons cables from their sockets on the motherboard.
在这个步骤中使用的工具:Tweezers$4.99
Connect the two capacitor wires briefly with a pair of metal tweezers to discharge the capacitor. You may see a small spark.
Remove eight screws using a Phillips #00 screwdriver.
Two (4.31 mm) screws are in the front of the camera.
Two (3.30 mm) screws are located in the bottom of the camera.
Four (3 x 3.33 mm and 1 x 4.34 mm) screws are in the back of the camera.
另外一个人完成了本指南。
