跳转到主内容
Kodak EasyShare LS743 Lens Replacement
你所需要的
  1. Kodak EasyShare LS743 Lens Replacement, Battery: 步骤 1 中的图像 1,1
    • Using your fingernail, open the battery cover.
  2. Kodak EasyShare LS743 Lens Replacement: 步骤 2 中的图像 1,1
    • Slide the orange latch sideways to eject the battery.
    • Remove the battery from the battery slot.
  3. Kodak EasyShare LS743 Lens Replacement, Kodak EasyShare LS743 Camera Case Disassembly: 步骤 3 中的图像 1,3 Kodak EasyShare LS743 Lens Replacement, Kodak EasyShare LS743 Camera Case Disassembly: 步骤 3 中的图像 2,3 Kodak EasyShare LS743 Lens Replacement, Kodak EasyShare LS743 Camera Case Disassembly: 步骤 3 中的图像 3,3
    • Using a Phillips #00 screwdriver, remove two 5.39 mm screws next to the battery slot.
    • Remove the metal piece holding down the lanyard, then remove the lanyard.
  4. Kodak EasyShare LS743 Lens Replacement: 步骤 4 中的图像 1,3 Kodak EasyShare LS743 Lens Replacement: 步骤 4 中的图像 2,3 Kodak EasyShare LS743 Lens Replacement: 步骤 4 中的图像 3,3
    • Using a Phillips #00 screwdriver, remove seven screws located on the outside case of the camera.
    • One 6.25 mm screw is located on the top right corner, right to the "OK" button.
    • Four 4.45 mm screws are on the bottom of the camera.
    • Two 2.95 mm screws are on the left side of the camera, above the USB port.
  5. Kodak EasyShare LS743 Lens Replacement: 步骤 5 中的图像 1,2 Kodak EasyShare LS743 Lens Replacement: 步骤 5 中的图像 2,2
    • Carefully remove the rear camera casing.
    • Carefully remove the front camera casing.
  6. Kodak EasyShare LS743 Lens Replacement, Top and menu buttons: 步骤 6 中的图像 1,2 Kodak EasyShare LS743 Lens Replacement, Top and menu buttons: 步骤 6 中的图像 2,2
    • Remove the top panel screw (1x 4.37mm).
  7. Kodak EasyShare LS743 Lens Replacement: 步骤 7 中的图像 1,2 Kodak EasyShare LS743 Lens Replacement: 步骤 7 中的图像 2,2
    • Remove the top panel.
  8. Kodak EasyShare LS743 Lens Replacement: 步骤 8 中的图像 1,2 Kodak EasyShare LS743 Lens Replacement: 步骤 8 中的图像 2,2
    • Remove the back panel screws (1x 3.33mm, and 1x 3.40mm).
  9. Kodak EasyShare LS743 Lens Replacement: 步骤 9 中的图像 1,3 Kodak EasyShare LS743 Lens Replacement: 步骤 9 中的图像 2,3 Kodak EasyShare LS743 Lens Replacement: 步骤 9 中的图像 3,3
    • Separate the inner casing from the tripod mount.
  10. Kodak EasyShare LS743 Lens Replacement: 步骤 10 中的图像 1,3 Kodak EasyShare LS743 Lens Replacement: 步骤 10 中的图像 2,3 Kodak EasyShare LS743 Lens Replacement: 步骤 10 中的图像 3,3
    • Gently pull the orange tab out of the circuit board.
  11. Kodak EasyShare LS743 Lens Replacement: 步骤 11 中的图像 1,2 Kodak EasyShare LS743 Lens Replacement: 步骤 11 中的图像 2,2
    • Carefully separate and flip over the LCD panel to expose the central circuit board.
  12. Kodak EasyShare LS743 Lens Replacement: 步骤 12 中的图像 1,1
    • Remove the (1x 3.33mm) screw from the menu button panel .
  13. Kodak EasyShare LS743 Lens Replacement: 步骤 13 中的图像 1,2 Kodak EasyShare LS743 Lens Replacement: 步骤 13 中的图像 2,2
    • Pull the second orange tab from the circuit board and remove the buttons.
  14. Kodak EasyShare LS743 Lens Replacement, Removing LCD: 步骤 14 中的图像 1,3 Kodak EasyShare LS743 Lens Replacement, Removing LCD: 步骤 14 中的图像 2,3 Kodak EasyShare LS743 Lens Replacement, Removing LCD: 步骤 14 中的图像 3,3
    • Flip up the LCD screen to reveal the two orange ribbon cables.
    • Disconnect the two ribbons cables from their sockets on the motherboard.
  15. Kodak EasyShare LS743 Lens Replacement, Capacitor: 步骤 15 中的图像 1,3 Kodak EasyShare LS743 Lens Replacement, Capacitor: 步骤 15 中的图像 2,3 Kodak EasyShare LS743 Lens Replacement, Capacitor: 步骤 15 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • The capacitor can store electricity even when the camera is off! Do not touch it until you have safely discharged it.
    • Connect the two capacitor wires briefly with a pair of metal tweezers to discharge the capacitor. You may see a small spark.
    • Remove eight screws using a Phillips #00 screwdriver.
    • Two (4.31 mm) screws are in the front of the camera.
    • Two (3.30 mm) screws are located in the bottom of the camera.
    • This causes the tripod mount on the bottom to become loose.
    • Four (3 x 3.33 mm and 1 x 4.34 mm) screws are in the back of the camera.
  16. Kodak EasyShare LS743 Lens Replacement: 步骤 16 中的图像 1,1
    • Remove the tripod mount from the bottom of the camera and set it aside.
  17. Kodak EasyShare LS743 Lens Replacement: 步骤 17 中的图像 1,1
    • Pull the black latch outward slightly to release the orange flex cable.
    • Carefully disconnect the orange flex cable.
  18. Kodak EasyShare LS743 Lens Replacement: 步骤 18 中的图像 1,1
    • Soldering irons pose a burn risk if handled improperly.
    • Desolder the red and black wire and remove them.
  19. Kodak EasyShare LS743 Lens Replacement: 步骤 19 中的图像 1,2 Kodak EasyShare LS743 Lens Replacement: 步骤 19 中的图像 2,2
    • Hold the camera firmly and gently remove the capacitor (attached by adhesive) by wiggling it loose.
    • Desolder the pink and black wire and remove both of them.
  20. Kodak EasyShare LS743 Lens Replacement, Lens: 步骤 20 中的图像 1,2 Kodak EasyShare LS743 Lens Replacement, Lens: 步骤 20 中的图像 2,2
    • Remove the (1x4.27) screw from the front of the camera.
  21. Kodak EasyShare LS743 Lens Replacement: 步骤 21 中的图像 1,2 Kodak EasyShare LS743 Lens Replacement: 步骤 21 中的图像 2,2
    • Remove the orange tabs from the back of the camera to remove the lens.
结论
另外一个人完成了本指南。
Elizabeth Loui
于06/24/10注册
81 声望
创作了2篇指南
团队
Cal Poly, Team 2-8, Johann Summer 2010 Cal Poly, Team 2-8, Johann Summer 2010 的会员
CPSU-JOHANN-R10S2G8
5 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 3,212
