本指南有最近更改,您可查看未经巡查的最新版本。
简介
This will teach you how to remove the capacitor in your Kodak EasyShare LS743.
你所需要的
Using a Phillips #00 screwdriver, remove two 5.39 mm screws next to the battery slot.
Remove the metal piece holding down the lanyard, then remove the lanyard.
Using a Phillips #00 screwdriver, remove seven screws located on the outside case of the camera.
One 6.25 mm screw is located on the top right corner, right to the "OK" button.
Four 4.45 mm screws are on the bottom of the camera.
Two 2.95 mm screws are on the left side of the camera, above the USB port.
Connect the two capacitor wires briefly with a pair of metal tweezers to discharge it. You may see a small spark.
Remove 8 screws.
2 screws in the front (2X 4.31mm).
2 screws on the bottom (2X3.30MM).
4 screws in the back (3x 3.33mm, and 1x 4.34mm).
另外一个人完成了本指南。
