跳转到主内容
Kodak EasyShare CD82 LCD Display Screen Replacement
你所需要的
  1. Kodak EasyShare CD82 LCD Display Screen Replacement, LCD Screen: 步骤 1 中的图像 1,3 Kodak EasyShare CD82 LCD Display Screen Replacement, LCD Screen: 步骤 1 中的图像 2,3 Kodak EasyShare CD82 LCD Display Screen Replacement, LCD Screen: 步骤 1 中的图像 3,3
    • Remove the batteries and the memory card from the device.
    • Remove the 2 screws located at the bottom of the device.
  2. Kodak EasyShare CD82 LCD Display Screen Replacement: 步骤 2 中的图像 1,3 Kodak EasyShare CD82 LCD Display Screen Replacement: 步骤 2 中的图像 2,3 Kodak EasyShare CD82 LCD Display Screen Replacement: 步骤 2 中的图像 3,3
    • Remove the 2 screws on the side, to the left of the camera lens.
    • Remove the 2 screws on the side, to the right of the camera lens.
    • Pry the casing from the device starting at the battery compartment and following the seem around the camera.
  3. Kodak EasyShare CD82 LCD Display Screen Replacement: 步骤 3 中的图像 1,3 Kodak EasyShare CD82 LCD Display Screen Replacement: 步骤 3 中的图像 2,3 Kodak EasyShare CD82 LCD Display Screen Replacement: 步骤 3 中的图像 3,3
    • Remove the front panel from the device first, then remove the back panel.
    • Do not remove the LCD screen from the device once it becomes visible.
  4. Kodak EasyShare CD82 LCD Display Screen Replacement: 步骤 4 中的图像 1,3 Kodak EasyShare CD82 LCD Display Screen Replacement: 步骤 4 中的图像 2,3 Kodak EasyShare CD82 LCD Display Screen Replacement: 步骤 4 中的图像 3,3
    • Flip the LCD screen away from the top of the device to reveal the ribbon cable.
    • This is water damage the has afflicted the camera.
    • Remove the 3 screws from the LCD screen holder.
    • Pry the screen holder from the circuit board connector.
  5. Kodak EasyShare CD82 LCD Display Screen Replacement: 步骤 5 中的图像 1,2 Kodak EasyShare CD82 LCD Display Screen Replacement: 步骤 5 中的图像 2,2
    • Disconnect the logic board from the right side of the frame.
    • Remove the small ribbon cable that is connecting the button panel to the logic board, using a small pair of tweezers or hemostat.
    • Remove the screw on the top right side of the device.
  6. Kodak EasyShare CD82 LCD Display Screen Replacement: 步骤 6 中的图像 1,2 Kodak EasyShare CD82 LCD Display Screen Replacement: 步骤 6 中的图像 2,2
    • Open the connector and move the black clip into the upward position, freeing the cable. Remove the LCD screen and the holder.
    • While the camera is disassembled, use isopropyl alcohol to remove rust and clean the device.
    • Follow these steps in reverse order to reassemble. The device should be fully functional upon completion.
结论
2等其他人完成本指南。
oldturkey03
于09/29/10注册
781,130 声望
创作了119篇指南
团队
Global Fixers Global Fixers 的会员
Community
32 名成员
创作了530篇指南
一条评论
Is there any repair for Kodak CD80 easy share camera…..as my camera is not working
Januchowdary - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 1,475
