跳转到主内容
Kodak EasyShare C913 LCD Screen Replacement
你所需要的
  1. Kodak EasyShare C913 LCD Screen Replacement, Batteries: 步骤 1 中的图像 1,3 Kodak EasyShare C913 LCD Screen Replacement, Batteries: 步骤 1 中的图像 2,3 Kodak EasyShare C913 LCD Screen Replacement, Batteries: 步骤 1 中的图像 3,3
    • Position the camera with the bottom facing up.
    • Slide the battery cover in the direction of the arrow with your finger gently.
    • Remove the batteries
  2. Kodak EasyShare C913 LCD Screen Replacement, Back Case: 步骤 2 中的图像 1,3 Kodak EasyShare C913 LCD Screen Replacement, Back Case: 步骤 2 中的图像 2,3 Kodak EasyShare C913 LCD Screen Replacement, Back Case: 步骤 2 中的图像 3,3
    • Remove the seven 4.5mm screws with a Phillips #00 screwdriver.
    • 2 screws on the left
    • 2 screws on the right
    • 3 screws on the bottom
  3. Kodak EasyShare C913 LCD Screen Replacement: 步骤 3 中的图像 1,3 Kodak EasyShare C913 LCD Screen Replacement: 步骤 3 中的图像 2,3 Kodak EasyShare C913 LCD Screen Replacement: 步骤 3 中的图像 3,3
    • Firmly grasp the back of the camera and pull the casing away.
  4. Kodak EasyShare C913 LCD Screen Replacement, Front Case: 步骤 4 中的图像 1,3 Kodak EasyShare C913 LCD Screen Replacement, Front Case: 步骤 4 中的图像 2,3 Kodak EasyShare C913 LCD Screen Replacement, Front Case: 步骤 4 中的图像 3,3
    • Keep the battery door open
    • Firmly grasp the front casing and pull it away from the camera.
  5. Kodak EasyShare C913 LCD Screen Replacement, LCD Screen: 步骤 5 中的图像 1,3 Kodak EasyShare C913 LCD Screen Replacement, LCD Screen: 步骤 5 中的图像 2,3 Kodak EasyShare C913 LCD Screen Replacement, LCD Screen: 步骤 5 中的图像 3,3
    • Look at the LCD casing and find the two smaller solder joints. One on either side of the camera secures the circuit board's casing. These are usually shiny and metallic points where the casing connects to the board.
    • Apply the tip of the heated smolder to the first joint to remove it. Contiune with the other side.
  6. Kodak EasyShare C913 LCD Screen Replacement: 步骤 6 中的图像 1,3 Kodak EasyShare C913 LCD Screen Replacement: 步骤 6 中的图像 2,3 Kodak EasyShare C913 LCD Screen Replacement: 步骤 6 中的图像 3,3
    • Gently grasp the lower right side of LCD screen.
    • Lift the screen out of its casing.
    • Remove the 3 mm screw from the LCD casing using a #00 screwdriver.
  7. Kodak EasyShare C913 LCD Screen Replacement: 步骤 7 中的图像 1,3 Kodak EasyShare C913 LCD Screen Replacement: 步骤 7 中的图像 2,3 Kodak EasyShare C913 LCD Screen Replacement: 步骤 7 中的图像 3,3
    • Gently grab the sides of the LCD casing and remove it from the camera.
  8. Kodak EasyShare C913 LCD Screen Replacement: 步骤 8 中的图像 1,2 Kodak EasyShare C913 LCD Screen Replacement: 步骤 8 中的图像 2,2
    • Lift the black tab gently with your finger.
    • Gently remove ribbon from underneath black tab.
结论
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
另外一个人完成了本指南。
Alan Galarza
于10/03/10注册
84 声望
创作了3篇指南
团队
Cal Poly, Team 7-51, Amido Fall 2010 Cal Poly, Team 7-51, Amido Fall 2010 的会员
CPSU-AMIDO-F10S7G51
4 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 4,699
