简介
This guide will help with replacing the lens of the Kodak EasyShare C713 Camera.
The errors you have been experiencing may have been caused by something as simple as dropping the camera with the lens extended, blocking the lens extension when it was turned on, or the batteries ran out with the lens extended. They also may be due to inner malfunctions in the camera itself. For example, if the lens is not fully extending, something may be wrong with a motor.
During this process, you will need to know how to solder and desolder points on a circuit board.
Make sure the camera is turned off before you begin.
你所需要的
Use your finger tip to slide battery cover door away from the center of the camera.
The battery door should spring open.
If this does not happen, gently open the door lifting from the outer bottom side of the camera.
Remove the seven screws from the outer case with a Phillips #00.
All screws are 4.45mm.
There are 2 screws on the port side.
There are 2 screws on starboard side.
There are 3 screws on the bottom.
Using a fingertip, flip the black tab near the top of the camera.
Remove the ribbon connector from inside the black tab.
另外一个人完成了本指南。
