跳转到主内容
Kodak EasyShare C713 LCD Replacement
你所需要的
  1. Kodak EasyShare C713 LCD Replacement, Batteries: 步骤 1 中的图像 1,1
    • Use your finger tip to slide battery cover door away from the center of the camera.
    • The battery door should spring open.
    • If this does not happen, gently open the door lifting from the outer bottom side of the camera.
  2. Kodak EasyShare C713 LCD Replacement: 步骤 2 中的图像 1,1
    • Remove the old batteries.
  3. Kodak EasyShare C713 LCD Replacement, Outer Case: 步骤 3 中的图像 1,3 Kodak EasyShare C713 LCD Replacement, Outer Case: 步骤 3 中的图像 2,3 Kodak EasyShare C713 LCD Replacement, Outer Case: 步骤 3 中的图像 3,3
    • Remove the seven screws from the outer case with a Phillips #00.
    • All screws are 4.45mm.
    • There are 2 screws on the port side.
    • There are 2 screws on starboard side.
    • There are 3 screws on the bottom.
  4. Kodak EasyShare C713 LCD Replacement: 步骤 4 中的图像 1,3 Kodak EasyShare C713 LCD Replacement: 步骤 4 中的图像 2,3 Kodak EasyShare C713 LCD Replacement: 步骤 4 中的图像 3,3
    • Make sure the battery cap is "up".
    • Pull the outer case off with your hands.
  5. Kodak EasyShare C713 LCD Replacement, LCD: 步骤 5 中的图像 1,1
    • The LCD screen is hinged at the bottom.
    • Put your thumb in the upper right corner of the LCD screen.
    • Pull the LCD screen out of its outer case with your thumb.
  6. Kodak EasyShare C713 LCD Replacement: 步骤 6 中的图像 1,1
    • Remove the screw underneath LCD screen with the Phillips #00. The screw measures 4.1mm in length.
  7. Kodak EasyShare C713 LCD Replacement: 步骤 7 中的图像 1,2 Kodak EasyShare C713 LCD Replacement: 步骤 7 中的图像 2,2
    • Desolder the two points.
    • One on the port side.
    • One on the bottom.
  8. Kodak EasyShare C713 LCD Replacement: 步骤 8 中的图像 1,1
    • After desoldering the LCD casing, just use your fingers to carefully remove it.
  9. Kodak EasyShare C713 LCD Replacement: 步骤 9 中的图像 1,1
    • Flip up the black tab on the bottom of the LCD screen with a fingertip.
  10. Kodak EasyShare C713 LCD Replacement: 步骤 10 中的图像 1,1
    • Remove the LCD ribbon cable from inside the black tab.
结论
6等其他人完成本指南。
Taggart Ashby
于04/15/10注册
354 声望
创作了4篇指南
团队
Cal Poly, Team 26-19, Regan Spring 2010 Cal Poly, Team 26-19, Regan Spring 2010 的会员
CPSU-REGAN-S10S26G19
4 名成员
创作了14篇指南
2条评论
Thank you... i fixed my old camera lcd.
anthoxman - 回复
hvor kan jeg kjøpe LCD skjermen til dette kamerat, og hva koster et sånn LCD-skjerm
fancy tassen - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 12
总计 5,255
