跳转到主内容
Kodak EasyShare C713 Capacitor Replacement
你所需要的
  1. Kodak EasyShare C713 Capacitor Replacement, Batteries: 步骤 1 中的图像 1,1
    • Use your finger tip to slide battery cover door away from the center of the camera.
    • The battery door should spring open.
    • If this does not happen, gently open the door lifting from the outer bottom side of the camera.
  2. Kodak EasyShare C713 Capacitor Replacement: 步骤 2 中的图像 1,1
    • Remove the old batteries.
  3. Kodak EasyShare C713 Capacitor Replacement, Outer Case: 步骤 3 中的图像 1,3 Kodak EasyShare C713 Capacitor Replacement, Outer Case: 步骤 3 中的图像 2,3 Kodak EasyShare C713 Capacitor Replacement, Outer Case: 步骤 3 中的图像 3,3
    • Remove the seven screws from the outer case with a Phillips #00.
    • All screws are 4.45mm.
    • There are 2 screws on the port side.
    • There are 2 screws on starboard side.
    • There are 3 screws on the bottom.
  4. Kodak EasyShare C713 Capacitor Replacement: 步骤 4 中的图像 1,3 Kodak EasyShare C713 Capacitor Replacement: 步骤 4 中的图像 2,3 Kodak EasyShare C713 Capacitor Replacement: 步骤 4 中的图像 3,3
    • Make sure the battery cap is "up".
    • Pull the outer case off with your hands.
  5. Kodak EasyShare C713 Capacitor Replacement, Capacitor: 步骤 5 中的图像 1,2 Kodak EasyShare C713 Capacitor Replacement, Capacitor: 步骤 5 中的图像 2,2
    • To avoid an electric shock, do not to touch capacitor.
    • The capacitor is located underneath the lens.
    • It is held in place by 4 plastic snaps; it can be easily removed by pulling outward with your fingers.
  6. Kodak EasyShare C713 Capacitor Replacement: 步骤 6 中的图像 1,1
    • Desolder points connecting capacitor to circuit board.
结论
2等其他人完成本指南。
团队
Cal Poly, Team 26-19, Regan Spring 2010 Cal Poly, Team 26-19, Regan Spring 2010 的会员
CPSU-REGAN-S10S26G19
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 4,160
