跳转到主内容
Kodak EasyShare C713 Battery Door Replacement
你所需要的
  1. Kodak EasyShare C713 Battery Door Replacement, Batteries: 步骤 1 中的图像 1,1
    • Use your finger tip to slide battery cover door away from the center of the camera.
    • The battery door should spring open.
    • If this does not happen, gently open the door lifting from the outer bottom side of the camera.
  2. Kodak EasyShare C713 Battery Door Replacement: 步骤 2 中的图像 1,1
    • Remove the old batteries.
  3. Kodak EasyShare C713 Battery Door Replacement, Outer Case: 步骤 3 中的图像 1,3 Kodak EasyShare C713 Battery Door Replacement, Outer Case: 步骤 3 中的图像 2,3 Kodak EasyShare C713 Battery Door Replacement, Outer Case: 步骤 3 中的图像 3,3
    • Remove the seven screws from the outer case with a Phillips #00.
    • All screws are 4.45mm.
    • There are 2 screws on the port side.
    • There are 2 screws on starboard side.
    • There are 3 screws on the bottom.
  4. Kodak EasyShare C713 Battery Door Replacement: 步骤 4 中的图像 1,3 Kodak EasyShare C713 Battery Door Replacement: 步骤 4 中的图像 2,3 Kodak EasyShare C713 Battery Door Replacement: 步骤 4 中的图像 3,3
    • Make sure the battery cap is "up".
    • Pull the outer case off with your hands.
  5. Kodak EasyShare C713 Battery Door Replacement, Battery Door: 步骤 5 中的图像 1,2 Kodak EasyShare C713 Battery Door Replacement, Battery Door: 步骤 5 中的图像 2,2
    • Make sure the battery door is open.
    • Using a pair of tweezers, remove the metal rod at the junction of the battery door and the inner camera case.
    • This rod serves as the hinge for the door.
    • Make sure not to lose the battery door spring which may fall when the rod is removed.
结论
另外一个人完成了本指南。
Trevor DeVore
于04/15/10注册
17 声望
撰写一个指南
团队
Cal Poly, Team 26-19, Regan Spring 2010 Cal Poly, Team 26-19, Regan Spring 2010 的会员
CPSU-REGAN-S10S26G19
4 名成员
创作了14篇指南
一条评论
Where do I buy a new battery door. Cheers, Peter
Peter - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 11
总计 5,164
