跳转到主内容
Kodak EasyShare C195 Memory Card Replacement
你所需要的
  1. Kodak EasyShare C195 Memory Card Replacement, Memory Card: 步骤 1 中的图像 1,3 Kodak EasyShare C195 Memory Card Replacement, Memory Card: 步骤 1 中的图像 2,3 Kodak EasyShare C195 Memory Card Replacement, Memory Card: 步骤 1 中的图像 3,3
    • First, access the slide door on the bottom left corner of the camera. To open, push down and to the left.
  2. Kodak EasyShare C195 Memory Card Replacement: 步骤 2 中的图像 1,3 Kodak EasyShare C195 Memory Card Replacement: 步骤 2 中的图像 2,3 Kodak EasyShare C195 Memory Card Replacement: 步骤 2 中的图像 3,3
    • The memory card slot is located just below the batteries.
    • To insert the memory card, make sure the writing is facing the batteries, and the cut off corner is at the top right. Put the card into the slot and push until you hear a click.
    • You do not need to remove the batteries to insert the memory card.
  3. Kodak EasyShare C195 Memory Card Replacement: 步骤 3 中的图像 1,1
    • This is what the memory card should look like when finished.
结论
To remove, push the memory card until you feel a click. The card should pop out.
Alyssa
于04/12/12注册
81 声望
创作了4篇指南
团队
Cal Poly, Team 6-22, Amido Spring 2012 Cal Poly, Team 6-22, Amido Spring 2012 的会员
CPSU-AMIDO-S12S6G22
4 名成员
创作了8篇指南
2条评论
Hi. I purchased a new memory card. When inserted into the camera, I can’t take a picture because the camera states internal memory full. What do I do??
katherine skorich-nelson - 回复
Bought a new memory card. Cannot take pictures because the screen states "internal memory full”. What do I do?
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 8
过去 30 天: 25
总计 2,425
