简介
This guide will show you how to take out and replace the LCD screen on your camera.
你所需要的
To start, remove the Philips #00 4.5 mm screws on both sides of the camera.
On the bottom, there are three Philips #00 4.5 mm screws. Two are for the front panel and one is for the back panel. To remove the back panel, take out the screws indicated in the final picture of the sequence.
To reassemble your device, follow these instructions in reverse order. NOTE: be sure to put the internal screws on the inside and the external screws on the outside.
4等其他人完成本指南。
