跳转到主内容
Kodak EasyShare C195 Batteries Replacement
你所需要的
  1. Kodak EasyShare C195 Batteries Replacement, Batteries: 步骤 1 中的图像 1,3 Kodak EasyShare C195 Batteries Replacement, Batteries: 步骤 1 中的图像 2,3 Kodak EasyShare C195 Batteries Replacement, Batteries: 步骤 1 中的图像 3,3
    • First, open the cover to the batteries. This is located on the bottom left of the camera.
    • Push the door down and to the left to open. This opens into the batteries and the memory card.
  2. Kodak EasyShare C195 Batteries Replacement: 步骤 2 中的图像 1,3 Kodak EasyShare C195 Batteries Replacement: 步骤 2 中的图像 2,3 Kodak EasyShare C195 Batteries Replacement: 步骤 2 中的图像 3,3
    • To insert the batteries, place them in the slots provided.
    • Make sure the positive and negative signs match with the positive and negative sides of the batteries.
  3. Kodak EasyShare C195 Batteries Replacement: 步骤 3 中的图像 1,3 Kodak EasyShare C195 Batteries Replacement: 步骤 3 中的图像 2,3 Kodak EasyShare C195 Batteries Replacement: 步骤 3 中的图像 3,3
    • When finished, you should have one battery positive side up and the other one negative side up.
结论
To close the door, push the door down and slide to the right
Alyssa
于04/12/12注册
96 声望
创作了4篇指南
团队
Cal Poly, Team 6-22, Amido Spring 2012 Cal Poly, Team 6-22, Amido Spring 2012 的会员
CPSU-AMIDO-S12S6G22
4 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 27
总计 3,888
