本指南有最近更改,您可查看未经巡查的最新版本。
简介
In order to complete the replacement, you will need a Phillips #00 Screwdriver as well as a replacement LCD for the camera already.
你所需要的
Carefully slide the LCD out of its holder until the connector, highlighted in blue, is visible. Open the clip on the connector by pulling it with your fingernail to the right of the screen.
Remove the damaged LCD and insert the replacement.
After clipping the connector again, reassemble the camera using the six (6) previously removed screws.
即将完成!
结论
