跳转到主内容
Kobo Arc K107 Speaker Replacement
你所需要的
  1. Kobo Arc K107 Speaker Replacement, Battery: 步骤 1 中的图像 1,1
    • Peel the back cover off of the Kobo Arc by finding the lip in the cover and pulling back on it.
  2. Kobo Arc K107 Speaker Replacement: 步骤 2 中的图像 1,1
    • Remove the screws from the midframe.
  3. Kobo Arc K107 Speaker Replacement: 步骤 3 中的图像 1,1
    • Use a nylon spudger to pry up the battery from the device.
    • It will give some resistance as it is glued down.
    • Always use plastic or nylon prying tools around the battery. Metal tools can puncture a battery, potentially causing a fire.
  4. Kobo Arc K107 Speaker Replacement: 步骤 4 中的图像 1,1
    • Unplug the battery connector from the rest of the tablet.
    • Remove the battery from the tablet.
  5. Kobo Arc K107 Speaker Replacement, Speaker: 步骤 5 中的图像 1,2 Kobo Arc K107 Speaker Replacement, Speaker: 步骤 5 中的图像 2,2
    • Remove the screws that are attached to the grey plastic layer.
    • Remove the gray plastic layer.
  6. Kobo Arc K107 Speaker Replacement: 步骤 6 中的图像 1,1
    • Disconnect the speakers from the tablet.
结论
Luke Maalouf
于10/28/21注册
85 声望
撰写一个指南
团队
UMass Dartmouth, Team 4-3, Gulbrandsen Fall 2021 UMass Dartmouth, Team 4-3, Gulbrandsen Fall 2021 的会员
UMASSD-GULBRANDSEN-F21S4G3
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 8
总计 83
