简介
Whether you use your blender to make smoothies or complicated dinner recipes, we understand that it plays an integral role in your daily routine. If your favorite blender stops working, don’t buy a new one! Save some money and repair all the common blender repair issues including leaks, broken switches, faulty motors, problems with the blade assembly, and more.
6 QT. STAND MIXER PROFESSIONAL 600 BOWL LIFT MODELS: KP26M1XMR5 (Meringue) KP26M1XPK5 (Pink) KP26M1XBS5 (Blue Steel) KP26M1XTG5 (Tangerine) KP26M1XCM5 (Cinnamon) 4KP26M1XMR5 (Meringue) KP26M1XDP5 (Dark Pewter) 4KP26M1XBS5 (Blue Steel) KP26M1XLC5 (Licorice) 4KP26M1XDP5 (Dark Pewter) KP26M1XMC5 (Metallic Chrome) 4KP26M1XLC5 (Licorice) KP26M1XNP5 (Nickel Pearl) 4KP26M1XMC5 (Metallic Chrome) KP26M1XPM5 (Pearl Metallic) 4KP26M1XNP5 (Nickel Pearl)
你所需要的
4等其他人完成本指南。
3指南评论
This is useless. It doesn't even show the motor being removed. You'd have to at least open the gearbox as well.
I'd recommend opening up the transmission housing, but actually it will slide in and out without opening it up. But its worth it just to grease up and its only 4 screws.
Careful when you remove the plugs on the power board, I had one where the solder joints broke from the board and the connector was still attached but no longer electrically connected. Try to get a spudger or anything to help pry connectors off, when pulling, pull straight out do not wiggle connectors.
I was able to fix the board by resoldering large globs on the back in to get it reconnect to the traces... Its working for now and if I had to I cut scrap off more of the PCB to reveal fresh traces to connect to but better to not have to do this.
Replacing the motor fixed the burning electric smell coming from the old one.
