跳转到主内容
加入维修社区 - 创建账户
KitchenAid KSM150PSER Carbon Brushes Replacement
你所需要的
  1. KitchenAid KSM150PSER Carbon Brushes Replacement, Carbon Brushes: 步骤 1 中的图像 1,2 KitchenAid KSM150PSER Carbon Brushes Replacement, Carbon Brushes: 步骤 1 中的图像 2,2
    • Using a flat head screwdriver, unscrew the brush cap on each side of the mixer by turning them counter clockwise.
    • Remove brush cap by pulling it toward you.
    • The brushes are held in by springs and will fly out if removed too fast.
    添加评论
  2. KitchenAid KSM150PSER Carbon Brushes Replacement: 步骤 2 中的图像 1,1
    • Remove brush by pulling it toward you.
    • One corner of the brush is flattened. You can check which way the brush is oriented by shining a flashlight inside the hole.
    添加评论
结论
取消:我没有完成这个指南。
8等其他人完成本指南。
Hayley Young
于12/03/16注册
253 声望
撰写一个指南
团队
Cal Poly, Team S2-G5, Livingston Winter 2018 Cal Poly, Team S2-G5, Livingston Winter 2018 的会员
CPSU-LIVINGSTON-W18S2G5
4 名成员
创作了16篇指南
1指南评论
I’ve been procrastinating on trying to fix my KA mixer on my own…today I did it. The directions were pretty clear and the only thing wrong was that when I had previously cleaned my mixer, I put the carbon brushes in the wrong way. Once I shined a flashlight into the hole I could see where the notched corner went.
Amber Reimer - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 26
过去 30 天: 141
总计 19,134
