简介
The ribbon cable connects the logic board to the motor. It looks like a gray ribbon with a red stripe.
你所需要的
Remove the glass container and place the blender upside down on a solid surface.
Remove the four rubber feet using the needle nose pliers.
Remove the four #7.5 Phillips 25mm screws that were located underneath the rubber feet using the Phillips #2 screwdriver.
Remove the two #6 Hex 82mm screws using the Phillips #2 screwdriver.
Remove the rubber O-ring by lifting it up.
Remove the ribbon cable from the chassis by lifting it up.
Remove the other end of the ribbon cable from the circuit board by lifting it up.
