跳转到主内容
KitchenAid KSB5CR Ribbon Cable Replacement
你所需要的
  1. KitchenAid KSB5CR Ribbon Cable Replacement, Removing the Back Panel Part 1: 步骤 1 中的图像 1,3 KitchenAid KSB5CR Ribbon Cable Replacement, Removing the Back Panel Part 1: 步骤 1 中的图像 2,3 KitchenAid KSB5CR Ribbon Cable Replacement, Removing the Back Panel Part 1: 步骤 1 中的图像 3,3
    • Remove the glass container and place the blender upside down on a solid surface.
    • Remove the four rubber feet using the needle nose pliers.
    • Remove the four #7.5 Phillips 25mm screws that were located underneath the rubber feet using the Phillips #2 screwdriver.
  2. KitchenAid KSB5CR Ribbon Cable Replacement, Removing the Back Panel Part 2: 步骤 2 中的图像 1,1
    • Lift the back panel up, sliding it along the power cord.
  3. KitchenAid KSB5CR Ribbon Cable Replacement, Removing the O-Ring: 步骤 3 中的图像 1,2 KitchenAid KSB5CR Ribbon Cable Replacement, Removing the O-Ring: 步骤 3 中的图像 2,2
    • Remove the two #6 Hex 82mm screws using the Phillips #2 screwdriver.
    • Remove the rubber O-ring by lifting it up.
  4. KitchenAid KSB5CR Ribbon Cable Replacement, Removing the Ribbon Cable: 步骤 4 中的图像 1,1
    • Remove the ribbon cable from the chassis by lifting it up.
    • Remove the other end of the ribbon cable from the circuit board by lifting it up.
结论
Cameron Geehr
于09/28/14注册
745 声望
创作了6篇指南
团队
Cal Poly, Team 12-5, Forte Fall 2014 Cal Poly, Team 12-5, Forte Fall 2014 的会员
CPSU-FORTE-F14S12G5
5 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 6
总计 471
