跳转到主内容
KitchenAid KHM512ER Power Cord Replacement
你所需要的
  1. KitchenAid KHM512ER Power Cord Replacement, Power Cord: 步骤 1 中的图像 1,2 KitchenAid KHM512ER Power Cord Replacement, Power Cord: 步骤 1 中的图像 2,2
    • Insert the back of a plastic opening tool into one of the beater holes
    • Apply force to pull the circular plastic part off.
    • If necessary, use the other side of the plastic opening tool to pry the circular plastic part off.
  2. KitchenAid KHM512ER Power Cord Replacement: 步骤 2 中的图像 1,3 KitchenAid KHM512ER Power Cord Replacement: 步骤 2 中的图像 2,3 KitchenAid KHM512ER Power Cord Replacement: 步骤 2 中的图像 3,3
    • Use a plastic opening tool to remove the speed knob.
    • Pop up the panel with a plastic opening tool.
    • Use a plastic opening tool to pry the white plastic switch assembly out.
  3. KitchenAid KHM512ER Power Cord Replacement: 步骤 3 中的图像 1,2 KitchenAid KHM512ER Power Cord Replacement: 步骤 3 中的图像 2,2
    • Use a Phillips 2 screwdriver to remove the two 20.0mm screws that hold the bottom plastic piece.
    • Your screwdriver may not be long or narrow enough to reach the screws in these holes. If that's the case, use another screwdriver.
    • Remove the bottom plastic piece using a plastic opening tool.
  4. KitchenAid KHM512ER Power Cord Replacement: 步骤 4 中的图像 1,3 KitchenAid KHM512ER Power Cord Replacement: 步骤 4 中的图像 2,3 KitchenAid KHM512ER Power Cord Replacement: 步骤 4 中的图像 3,3
    • Using a Phillips 2 screwdriver, remove the three 20.0mm screws holding the motor assembly in place.
    • Use your hands to remove the motor assembly and circuit board.
  5. KitchenAid KHM512ER Power Cord Replacement: 步骤 5 中的图像 1,3 KitchenAid KHM512ER Power Cord Replacement: 步骤 5 中的图像 2,3 KitchenAid KHM512ER Power Cord Replacement: 步骤 5 中的图像 3,3
    • Firmly grip the circuit board, and using pliers, remove the black and white power cord connectors from the circuit board.
    • Some force may be required. Be careful not to cut yourself on any electrical components.
  6. KitchenAid KHM512ER Power Cord Replacement: 步骤 6 中的图像 1,3 KitchenAid KHM512ER Power Cord Replacement: 步骤 6 中的图像 2,3 KitchenAid KHM512ER Power Cord Replacement: 步骤 6 中的图像 3,3
    • Using a plastic opening tool, remove the white plastic clip on the inside of the bottom plastic piece.
    • Once it's loose, remove it with your fingers.
    • Pull the power cord through the hole.
结论
另外一个人完成了本指南。
Brad Daniels
于02/10/16注册
621 声望
创作了3篇指南
团队
USF Tampa, Team 2-3, Sullivan Spring 2016 USF Tampa, Team 2-3, Sullivan Spring 2016 的会员
USFT-SULLIVAN-S16S2G3
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 26
总计 3,632
