跳转到主内容
加入维修社区 - 创建账户
KitchenAid KHM512ER Eject Button Spring Replacement
你所需要的
    1. KitchenAid KHM512ER Eject Button Spring Replacement, Eject Button Spring: 步骤 1 中的图像 1,2 KitchenAid KHM512ER Eject Button Spring Replacement, Eject Button Spring: 步骤 1 中的图像 2,2
      • Insert the back of a plastic opening tool into one of the beater holes.
      • Apply force to pull the circular plastic part off.
      • If necessary, use the other side of the plastic opening tool to pry the circular plastic part off.
      询问修复机器人
      添加评论
    2. KitchenAid KHM512ER Eject Button Spring Replacement: 步骤 2 中的图像 1,3 KitchenAid KHM512ER Eject Button Spring Replacement: 步骤 2 中的图像 2,3 KitchenAid KHM512ER Eject Button Spring Replacement: 步骤 2 中的图像 3,3
      • Use a plastic opening tool to remove the speed knob.
      • Use a plastic opening tool to remove the long plastic piece
      • Use a plastic opening tool to remove the speed switch.
      询问修复机器人
      添加评论
    3. KitchenAid KHM512ER Eject Button Spring Replacement: 步骤 3 中的图像 1,2 KitchenAid KHM512ER Eject Button Spring Replacement: 步骤 3 中的图像 2,2
      • Use a Phillips 2 screwdriver to remove the two 20.0mm screws holding the bottom plastic piece on.
      • Your screwdriver may not be long or narrow enough to reach the screws in these holes. If that's the case, use another screwdriver.
      • Remove the bottom plastic piece using a plastic opening tool.
      询问修复机器人
      添加评论
    4. KitchenAid KHM512ER Eject Button Spring Replacement: 步骤 4 中的图像 1,3 KitchenAid KHM512ER Eject Button Spring Replacement: 步骤 4 中的图像 2,3 KitchenAid KHM512ER Eject Button Spring Replacement: 步骤 4 中的图像 3,3
      • Using a Phillips 2 screwdriver, remove the three 20.0mm screws holding the motor assembly in place.
      • Use your hands to remove the motor assembly.
      • Use your hands to hold the eject button from one side while using the other hand to remove the circuit board.
      询问修复机器人
      添加评论
    5. KitchenAid KHM512ER Eject Button Spring Replacement: 步骤 5 中的图像 1,2 KitchenAid KHM512ER Eject Button Spring Replacement: 步骤 5 中的图像 2,2
      • Remove the eject button by pulling it from the inside of the mixer.
      • Hold the eject button firmly while pulling out the spring.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
USF Tampa, Team 2-3, Sullivan Spring 2016 USF Tampa, Team 2-3, Sullivan Spring 2016 的会员
USFT-SULLIVAN-S16S2G3
3 名成员
创作了9篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 36
总计 2,107
