跳转到主内容
你所需要的
  1. KitchenAid KHM512ER Beater Rings Replacement, Beater Rings: 步骤 1 中的图像 1,2 KitchenAid KHM512ER Beater Rings Replacement, Beater Rings: 步骤 1 中的图像 2,2
    • Insert the back of a plastic opening tool into one of the beater holes
    • Apply force to pull the circular plastic part off.
    • If necessary, use the other side of the plastic opening tool to pry the circular plastic part off.
  2. KitchenAid KHM512ER Beater Rings Replacement: 步骤 2 中的图像 1,2 KitchenAid KHM512ER Beater Rings Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #2 screwdriver to remove the two 20mm screws holding the bottom plastic piece in place.
    • Remove the bottom plastic piece using a plastic opening tool.
  3. KitchenAid KHM512ER Beater Rings Replacement: 步骤 3 中的图像 1,2 KitchenAid KHM512ER Beater Rings Replacement: 步骤 3 中的图像 2,2
    • Using a Phillips 2 screwdriver, remove the three 20.0mm screws holding the motor assembly in place.
    • Use your hands to remove the motor assembly.
  4. KitchenAid KHM512ER Beater Rings Replacement: 步骤 4 中的图像 1,2 KitchenAid KHM512ER Beater Rings Replacement: 步骤 4 中的图像 2,2
    • Firmly grip the motor in your hand. Using pliers, pull the connectors off the motors.
    • Some force may be required. Be careful not to cut yourself on any electrical components.
  5. KitchenAid KHM512ER Beater Rings Replacement: 步骤 5 中的图像 1,2 KitchenAid KHM512ER Beater Rings Replacement: 步骤 5 中的图像 2,2
    • Lie the motor down flat on a table.
    • Using a pair of tweezers, remove the ring from the plastic knob.
结论
3等其他人完成本指南。
Brad Daniels
于2016年02月10日注册
561 声望
创作了3篇指南
团队
USF Tampa, Team 2-3, Sullivan Spring 2016 USF Tampa, Team 2-3, Sullivan Spring 2016 的会员
USFT-SULLIVAN-S16S2G3
3 名成员
创作了4篇指南
3条评论
Anyone know of a site that sells replacement beater gears?
joescherzo - 回复
Nice set by step process but where does one get the rings?
M Stevens - 回复
try Sears parts.com
Yvette Tower - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 73
总计 5,613
