简介
If your mixer won't spin or is noisy, follow our guide on how to replace the worm gear.
你所需要的
Using a butter knife or putty knife, remove the grease from the gears.
Place the grease in motor housing cover.
57等其他人完成本指南。
28条评论
Some corrections:
Step 1 -- Suggest (as the Service Manual does) using a flat-blade screwdriver and tap it with a light hammer to drive the drip ring off.
Step 2 -- the correct size pin punch is 5/32"
Step 3 -- Using two flat-blade screwdrivers, one on each side, pry off the planetary.
A plastic spudger is likely to break. Two points of leverage opposits each other distributes the load and prevents to the planetary and its shaft.
Step 11 -- The proper punch size is 3/32"
Steps 12 & 13 -- There is a washer on each side of the worm gear. Retain these and place one on each side off the grar when reassembling.
A link to the Service Manual:
Finkerbell - 回复
Cheers Finkerbell,
Very helpful info, as was the main part of the guide.
Not sure what model number I was working on, but when I l lifted off the motor housing, there was still wires connected to the base.
Just be careful at this stage in case you have the same...
markguerin - 回复
my model K5SS WH is the same as yours until step 5. It doesnt have the two bolts as shown in the picture for step 5 so i wasnt able to complete the repair. any suggestions.
sailsetter - 回复
This is the BEST! Thank you.
Advanamics - 回复
