跳转到主内容
KitchenAid Classic Mixer K45SSWH Beater Head Adjustment
你所需要的
  1. KitchenAid Classic Mixer K45SSWH Beater Head Adjustment, Adjust the height: 步骤 1 中的图像 1,2 KitchenAid Classic Mixer K45SSWH Beater Head Adjustment, Adjust the height: 步骤 1 中的图像 2,2
    • Lift the mixer arm and locate the large screw where the base meets the arm.
    • Using a flathead screwdriver, turn the screw counter-clockwise to raise the beater head or turn it clockwise to lower the beater head.
    • The beater head should pass only about 1/16th of an inch above the base of the bowl. One good way to get the height right is to place a dime in the bowl and adjust the height until the beater head barely brushes the dime as it passes.
结论
Once your beater head is at the appropriate height, you're good to go.
4等其他人完成本指南。
Markus Gemperle
于10/13/14注册
639 声望
创作了2篇指南
团队
Cal Poly, Team 14-28, Maness Fall 2014 Cal Poly, Team 14-28, Maness Fall 2014 的会员
CPSU-MANESS-F14S14G28
4 名成员
创作了22篇指南
2条评论
Very helpful. Thank you for the info, it worked!!
suz - 回复
I have a K5ss by Hobbart. Do you know how to adjust the bowl/beater clearance.?This machine does not have the screw that adjusts the clearance like the K45ss does. The manual tells how to turn a screw to adjust the clearance on a k45ss, but says to consult an authorized dealer for the k5ss. I called around and nobody in my area works on mixers. Is this something I can do myself? Any help would be appreciated.
Aide L. - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 17
过去 30 天: 84
总计 13,652
