简介
While rare, being the only plastic piece in the bowl-lift mechanism, occasionally the internal bowl-lift adjustment bracket can fail. This can cause the bowl-lift arm to either no longer function or cause the bowl to not raise/lock into its proper position. This guide takes you step-by-step through replacing the incorrectly functioning part.
NOTE: This part is not responsible for setting the final/locked height of the bowl. That is the responsibility of the Bowl-Lift Arm Adjustment Cam. So if your bowl is raising too high or just barely too low, look into replacing that part instead.
你所需要的
Place some dish towels or other soft material in the base to protect it from any potential impact.
Disconnect the planetary from the motor drive shaft by removing the retaining pin (circled in yellow). You can do this with a hammer and either a pin punch or a Torx T15 screwdriver. Simply hammer the punch/screwdriver on the pin until it comes out the other side.
If the planetary assembly doesn't fall out, you might have to give it a firm pull straight down to remove it.
Using a #2 Philips Screwdriver, remove the screw which holds on the trim band.
Remove the trim band.
Remove the four screws (circled in yellow, two on each side) using a #2 Philips Screwdriver
Remove the cover by lifting it straight up.
Using the T25 Torx Screwdriver, remove the four torx screws by the powertrain (circled in yellow, two on each side)
When removing the last screw, make sure to place your hand under the planetary gear as it is heavy and will fall out immediately.
Remove the hall effect sensor from its mount by pressing down on the tab (circled in yellow in the first picture) and sliding it out.
Disconnect the power cable by holding down the clip on the right side of the plug (circled in blue) and pulling the plug straight up.
The powertrain is comprised of the motor, the gearbox, and the transfer gears. Unlike previous generations of KitchenAid AC Motor bowl-lift mixers, which had these broken in to discrete parts, this is a single unit.
Using a #2 Philips screwdriver, remove the four screws (circled in yellow, two on each side) attaching the powertrain to the mixer body.
Place the powertrain to the side, taking care not to damage any of the plastic parts like the rear fan.
Using a #2 Philips screwdriver, remove the two screws (circled in yellow in the first image) holding the speed/motor control assembly to the mixer body.
Pivot the assembly up to reveal the power connector (circled in blue in the second image).
Disconnect the power connector from the speed/motor control assembly by depressing the tab (circled in green in the third image) and pulling upwards.
Set the speed/motor control assembly to the side.
Using a #2 Philips screwdriver, remove the screw (circled in yellow) which attached the ground lead to the mixer body.
Remove the power cord by lifting up at the strain relief where it passes into the mixer (circled in blue).
Now comes the hard part: Using a #3 Phillips Screwdriver, remove the three screws holding down the coverplate and attaching the lower gearcase to the mixer body.
These screws are extremely difficult to remove. If you are not strong enough to remove them, an impact screwdriver can be used to remove them.
Lift straight up on the lower gearcase to remove it from the alignment pins (circled in blue in the second picture) and expose the bowl-lift mechanism.
When reinstalling, make sure these alignment pins are inserted into the lower gearcase correctly and the screws are reinstalled super tight.
Using a #1 Phillips Screwdriver, remove the small screw anchoring the Bowl-Lift Arm Adjusting Bracket to the handle.
Slide the handle out from the mixer body, as shown in the second picture. Continue sliding the handle out until the Bowl-Lift Arm Adjusting Bracket comes free.
Using needle nose pliers, detach the C-clip holding the Bowl-Lift Arm Adjusting Bracket from the Bowl-Lift Rod (circled in green). Then remove the Bowl-Lift Arm Adjusting Bracket by sliding it off the Bowl-Lift Rod.
Replace the Bowl-Lift Arm Adjusting Bracket.
If you have difficulty accessing the screw hole for the Bowl-Lift Arm Adjusting Bracket, insert the handle fully into position and rotate the handle until the screw hole aligns with the notch in the Bowl-Lift Arm Adjusting Bracket
另外一个人完成了本指南。
