跳转到主内容
Kitchen Gourmet Waffle Maker Release Latch Spring Replacement
你所需要的
  1. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement, Release Latch Spring: 步骤 1 中的图像 1,1
    • Unplug the waffle maker.
  2. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: 步骤 2 中的图像 1,3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: 步骤 2 中的图像 2,3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: 步骤 2 中的图像 3,3
    • Open the waffle maker.
    • Make sure the waffle maker's surface is not hot.
  3. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: 步骤 3 中的图像 1,3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: 步骤 3 中的图像 2,3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: 步骤 3 中的图像 3,3
    • Spray the interior of the waffle maker with cleaning solution.
    • Clean and wipe down the surface.
  4. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: 步骤 4 中的图像 1,2 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: 步骤 4 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the four screws that secure the plastic handle cover.
    • Spin in counterclockwise direction to loosen.
  5. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: 步骤 5 中的图像 1,3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: 步骤 5 中的图像 2,3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: 步骤 5 中的图像 3,3
    • Carefully pull back the plastic cover, and gently remove the release latch.
  6. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: 步骤 6 中的图像 1,2 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: 步骤 6 中的图像 2,2
    • Remove the spring from the latch.
  7. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: 步骤 7 中的图像 1,3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: 步骤 7 中的图像 2,3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: 步骤 7 中的图像 3,3
    • Carefully replace with the new spring.
    • Pliers are recommended but removal with hands is fine.
    • Be careful not to bend the spring when pushing into the plastic handle.
  8. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: 步骤 8 中的图像 1,3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: 步骤 8 中的图像 2,3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: 步骤 8 中的图像 3,3
    • Orient the release latch in the correct direction, and line up the spring.
  9. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: 步骤 9 中的图像 1,3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: 步骤 9 中的图像 2,3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: 步骤 9 中的图像 3,3
    • Hold the latch in place.
    • Line up the screw holes on the plastic cover to the waffle maker lid.
  10. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: 步骤 10 中的图像 1,2 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: 步骤 10 中的图像 2,2
    • Screw in all four screws tightly.
    • Spin in clockwise direction to tighten.
    • Screw in opposing screws first to keep them in place.
结论
Fatima Ruiz Ruiz
于02/01/24注册
193 声望
撰写一个指南
团队
UC Davis, Team 3-4, Andersen Winter 2024 UC Davis, Team 3-4, Andersen Winter 2024 的会员
UCD-ANDERSEN-W24S3G4
3 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 23
总计 107
