跳转到主内容
加入维修社区 - 创建账户
Kitchen Drawer Rear Mounts Replacement
你所需要的
  1. Kitchen Drawer Rear Mounts Replacement, Rear drawer mounts: 步骤 1 中的图像 1,2 Kitchen Drawer Rear Mounts Replacement, Rear drawer mounts: 步骤 1 中的图像 2,2
    • Remove all utensils from the drawer and remove the drawer from the slot.
  2. Kitchen Drawer Rear Mounts Replacement: 步骤 2 中的图像 1,2 Kitchen Drawer Rear Mounts Replacement: 步骤 2 中的图像 2,2
    • Start removing the mounts and tracks by unscrewing them with your drill or screwdriver.
    • Your replacement tracks or mounts will come with new screws.
  3. Kitchen Drawer Rear Mounts Replacement: 步骤 3 中的图像 1,1
    • Once you have all your new material, insert the mounts onto your track.
  4. Kitchen Drawer Rear Mounts Replacement: 步骤 4 中的图像 1,1
    • Take the track with the new mount attached and screw it into the existing hole using the new screws that came in the packaging.
  5. Kitchen Drawer Rear Mounts Replacement: 步骤 5 中的图像 1,2 Kitchen Drawer Rear Mounts Replacement: 步骤 5 中的图像 2,2
    • After the track has one screw drilled, use a level to make sure your track is straight.
    • Depending on your new mounts, you may or may not need to drill new holes for the screws. If you do need to drill new holes mark the holes on the mount with a pencil or marker.
  6. Kitchen Drawer Rear Mounts Replacement: 步骤 6 中的图像 1,1
    • Drill the screws in either the existing holes or marked spots to hold the mount in place.
  7. Kitchen Drawer Rear Mounts Replacement: 步骤 7 中的图像 1,1
    • Repeat these steps on the other side if needed.
  8. Kitchen Drawer Rear Mounts Replacement: 步骤 8 中的图像 1,1
    • Place your drawer back into its place and you are now done with your repair!
结论
Now that your repair is done make sure your drawer is sliding smoothly if not you will need to remove it and clean the tracks. Another thing to look for is if the tracks are perfectly aligned if not you can go back in and fix them by following the same steps again.
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 27
过去 30 天: 89
总计 3,905
