跳转到主内容
Kirby G5 Vacuum Belt Replacement
你所需要的
  1. Kirby G5 Vacuum Belt Replacement, Vacuum Belt: 步骤 1 中的图像 1,1
    • Place the vacuum at an angle most comfortable and easy to access with the bottom facing upwards.
  2. Kirby G5 Vacuum Belt Replacement: 步骤 2 中的图像 1,2 Kirby G5 Vacuum Belt Replacement: 步骤 2 中的图像 2,2
    • Remove the three screws holding the base plate to the body of the vacuum using a flat head screwdriver.
    • Place the plate to the side.
  3. Kirby G5 Vacuum Belt Replacement: 步骤 3 中的图像 1,1
    • Simply slide the roller out of the vacuum.
    • The belt is attached to the roller on either side.
  4. Kirby G5 Vacuum Belt Replacement: 步骤 4 中的图像 1,2 Kirby G5 Vacuum Belt Replacement: 步骤 4 中的图像 2,2
    • Slide the vacuum belt out from beneath the wheel holding it in place.
  5. Kirby G5 Vacuum Belt Replacement: 步骤 5 中的图像 1,1
    • Insert your new belt and pop the roller back into place.
  6. Kirby G5 Vacuum Belt Replacement: 步骤 6 中的图像 1,2 Kirby G5 Vacuum Belt Replacement: 步骤 6 中的图像 2,2
    • Secure the plate once again until it clicks into the made grooves.
    • Secure the three screws until tightened.
结论
Make sure to test the vacuum and securely tighten all screws. With that, you’re good to go!
另外一个人完成了本指南。
Gina Trojano
于04/22/21注册
157 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 58
总计 1,118
