跳转到主内容
Kindle Voyage Wifi Antenna Replacement
你所需要的
  1. Kindle Voyage Wifi Antenna Replacement, Back Panel: 步骤 1 中的图像 1,2 Kindle Voyage Wifi Antenna Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Insert a plastic opening tool between the plastic panel shown on the device.
    • Use the tool to pry the plastic away from the device.
    • There will be adhesive holding this piece of plastic to the device. You may have to pull pretty hard to get it separated.
  2. Kindle Voyage Wifi Antenna Replacement: 步骤 2 中的图像 1,1
    • Use an aluminum driver attached with a Phillips head size #00 to remove the four 3mm screws shown in the picture. For reassembly, note that the top two and bottom two screws are different sizes.
  3. Kindle Voyage Wifi Antenna Replacement: 步骤 3 中的图像 1,3 Kindle Voyage Wifi Antenna Replacement: 步骤 3 中的图像 2,3 Kindle Voyage Wifi Antenna Replacement: 步骤 3 中的图像 3,3
    • Once the screws are removed, the back panel can slide off the device.
  4. Kindle Voyage Wifi Antenna Replacement: 步骤 4 中的图像 1,2 Kindle Voyage Wifi Antenna Replacement: 步骤 4 中的图像 2,2
    • Remove the magnetic component with the magnetic head of the aluminum driver.
  5. Kindle Voyage Wifi Antenna Replacement, Wifi Antenna: 步骤 5 中的图像 1,2 Kindle Voyage Wifi Antenna Replacement, Wifi Antenna: 步骤 5 中的图像 2,2
    • Use an aluminum driver with Phillips head #00 to remove the four 3 mm screws shown in the picture.
    • Use the same driver to remove the two 2.5 mm screws.
  6. Kindle Voyage Wifi Antenna Replacement: 步骤 6 中的图像 1,3 Kindle Voyage Wifi Antenna Replacement: 步骤 6 中的图像 2,3 Kindle Voyage Wifi Antenna Replacement: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Using the tweezers, undo the attached clip.
    • Remove the three 3 mm screws holding down the rest of the antenna with an aluminum driver and the Phillips #00 head.
    • You should now be able to simply take the WiFi bar off of the device.
结论
Sean Yap
于01/22/15注册
1,351 声望
创作了6篇指南
团队
Cal Poly, Team 19-12, Maness Winter 2015 Cal Poly, Team 19-12, Maness Winter 2015 的会员
CPSU-MANESS-W15S19G12
5 名成员
创作了10篇指南
一条评论
Re Kindle Voyage Wifi Antenna Replacement guide: I cannot find the WiFi antenna bar on your website to purchase a replacement. Do you sell it?
carol cooper - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 15
总计 1,985
