简介
Vibration is a useful tool to ensure the user that a device is responding to the press of a button. This guide shows how to replace the vibrator in a Kindle Voyage should the device fail to vibrate properly.
你所需要的
Insert a plastic opening tool between the plastic panel shown on the device.
Use the tool to pry the plastic away from the device.
Use tweezers to pinch in the sides of the vibrator cable and slide it out of its housing.
一条评论
OK, the procedure seems straightforward enough, but you say “no parts required” when you actually *do* need to buy the replacement parts for the pieces that are no longer functioning. Where can you buy these parts?
