跳转到主内容
Kindle Voyage Battery Replacement
你所需要的
  1. Kindle Voyage Battery Replacement, Back Panel: 步骤 1 中的图像 1,2 Kindle Voyage Battery Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Insert a plastic opening tool between the plastic panel shown on the device.
    • Use the tool to pry the plastic away from the device.
    • There will be adhesive holding this piece of plastic to the device. You may have to pull pretty hard to get it separated.
  2. Kindle Voyage Battery Replacement: 步骤 2 中的图像 1,1
    • Use an aluminum driver attached with a Phillips head size #00 to remove the four 3mm screws shown in the picture. For reassembly, note that the top two and bottom two screws are different sizes.
  3. Kindle Voyage Battery Replacement: 步骤 3 中的图像 1,3 Kindle Voyage Battery Replacement: 步骤 3 中的图像 2,3 Kindle Voyage Battery Replacement: 步骤 3 中的图像 3,3
    • Once the screws are removed, the back panel can slide off the device.
  4. Kindle Voyage Battery Replacement: 步骤 4 中的图像 1,2 Kindle Voyage Battery Replacement: 步骤 4 中的图像 2,2
    • Remove the magnetic component with the magnetic head of the aluminum driver.
  5. Kindle Voyage Battery Replacement, Battery: 步骤 5 中的图像 1,2 Kindle Voyage Battery Replacement, Battery: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    购买
    • Use a plastic card to pry the battery away from the device.
    • Gently un-clip the battery plug from the device and remove the battery.
结论
27等其他人完成本指南。
Sean Yap
于01/22/15注册
1,253 声望
创作了6篇指南
团队
Cal Poly, Team 19-12, Maness Winter 2015 Cal Poly, Team 19-12, Maness Winter 2015 的会员
CPSU-MANESS-W15S19G12
5 名成员
创作了8篇指南
15条评论
Where can I buy a replacement buttery for my kindle voyage?
hegi88 - 回复
Where to find a replacement battery for kindle voyage 3G please if any one knows
Himadri Endow - 回复
Bump. Cannot seem to procure a new battery for the Kindle Voyage. Nice to know how to replace the old one; just need something to replace it WITH! Thanks for any hints on finding one. Battery model number is: MC-305070, 3.8V 1320mAh/5.01Wh, P/N 58-000056
larryg - 回复
Any advance on where one can find a replacement battery for the Kindle Journal?
Charles WRIGHT - 回复
Still looking for a source for this battery.
Neil Hall - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 108
过去 30 天: 504
总计 27,099
