跳转到主内容
Kindle Voyage Back Panel Replacement
你所需要的
  1. Kindle Voyage Back Panel Replacement, Back Panel: 步骤 1 中的图像 1,2 Kindle Voyage Back Panel Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Insert a plastic opening tool between the plastic panel shown on the device.
    • Use the tool to pry the plastic away from the device.
    • There will be adhesive holding this piece of plastic to the device. You may have to pull pretty hard to get it separated.
  2. Kindle Voyage Back Panel Replacement: 步骤 2 中的图像 1,1
    • Use an aluminum driver attached with a Phillips head size #00 to remove the four 3mm screws shown in the picture. For reassembly, note that the top two and bottom two screws are different sizes.
  3. Kindle Voyage Back Panel Replacement: 步骤 3 中的图像 1,3 Kindle Voyage Back Panel Replacement: 步骤 3 中的图像 2,3 Kindle Voyage Back Panel Replacement: 步骤 3 中的图像 3,3
    • Once the screws are removed, the back panel can slide off the device.
  4. Kindle Voyage Back Panel Replacement: 步骤 4 中的图像 1,2 Kindle Voyage Back Panel Replacement: 步骤 4 中的图像 2,2
    • Remove the magnetic component with the magnetic head of the aluminum driver.
结论
3等其他人完成本指南。
Sean Yap
于01/22/15注册
1,351 声望
创作了6篇指南
团队
Cal Poly, Team 19-12, Maness Winter 2015 Cal Poly, Team 19-12, Maness Winter 2015 的会员
CPSU-MANESS-W15S19G12
5 名成员
创作了10篇指南
4条评论
I'm having trouble getting the last two clips to snap back together on the top of the device. I'm pinching them together at the top, but nothing happens. It doesn't seem like it should be this difficult. What do you advise? Thanks!
Hannah BP - 回复
I have the same problem. It would be very helpful to get a tip here.
Sylvia Liemer - 回复
I 'm having the same problem with Hanna:
I' having trouble getting the last two clips to snap back together on the top of the device. I'm pinching them together at the top, but nothing happens. It doesn't seem like it should be this difficult. What do you advise? Thanks!
panthalas15 - 回复
Years later, but I just replaced the battery in mine and figured this out. You have to align the top clips first (and may have to lightly pry them open before you do that). Then bow the piece of plastic slightly and get the bottom clips in.
Patrick Cohen (ig88b) -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 14
过去 30 天: 59
总计 2,791
