简介
Use this guide to properly replace your speakers.
你所需要的
Use the plastic opening tool to undo the six plastic clips around the bottom of the back panel of the Kindle.
Using a Phillips #00 screwdriver, remove the six 4 mm screws to access the front plate.
Use the pointy end of your Spudger to separate the Speaker's connector from the motherboard on both sides.
即将完成!
结论
