跳转到主内容
Kindle Touch Speaker Replacement
你所需要的
  1. Kindle Touch Speaker Replacement, Back Cover: 步骤 1 中的图像 1,3 Kindle Touch Speaker Replacement, Back Cover: 步骤 1 中的图像 2,3 Kindle Touch Speaker Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Use the plastic opening tool to undo the six plastic clips around the bottom of the back panel of the Kindle.
    • Don't pry the clips on the top half of the back panel.
  2. Kindle Touch Speaker Replacement: 步骤 2 中的图像 1,2 Kindle Touch Speaker Replacement: 步骤 2 中的图像 2,2
    • Slide the back panel downward, toward the charging port. This will release the clips on the top half.
    • Once the top clips release, gently lift the back panel away.
  3. Kindle Touch Speaker Replacement, Battery: 步骤 3 中的图像 1,3 Kindle Touch Speaker Replacement, Battery: 步骤 3 中的图像 2,3 Kindle Touch Speaker Replacement, Battery: 步骤 3 中的图像 3,3
    • Use a Phillips #00 screwdriver to remove the five screws.
  4. Kindle Touch Speaker Replacement: 步骤 4 中的图像 1,3 Kindle Touch Speaker Replacement: 步骤 4 中的图像 2,3 Kindle Touch Speaker Replacement: 步骤 4 中的图像 3,3
    • Using the flat end of your spudger, gently pry the battery up and remove it.
  5. Kindle Touch Speaker Replacement, Bezel: 步骤 5 中的图像 1,2 Kindle Touch Speaker Replacement, Bezel: 步骤 5 中的图像 2,2
    • Using a Phillips #00 screwdriver, remove the six 4 mm screws to access the front plate.
  6. Kindle Touch Speaker Replacement: 步骤 6 中的图像 1,3 Kindle Touch Speaker Replacement: 步骤 6 中的图像 2,3 Kindle Touch Speaker Replacement: 步骤 6 中的图像 3,3
    • Use the plastic opening tool to pry the bezel from the top and sides
    • The bottom of the bezel will be glued, so be careful when sliding the clips out.
    • The clips can be easily bent, so do not try to force them out. If you do bend some, they can be bent back.
  7. Kindle Touch Speaker Replacement, Rear Casing: 步骤 7 中的图像 1,1
    • Use your Phillips #00 srewdriver to remove the indicated screws.
    • There are three pairs of screws that are each different. The screws on the top corners are 4 mm #00 Phillips screws, the screws on the bottom corners are 2 mm #00 Phillips screws, and the black bottom center screws are 6 mm #00 Phillips screws.
  8. Kindle Touch Speaker Replacement: 步骤 8 中的图像 1,2 Kindle Touch Speaker Replacement: 步骤 8 中的图像 2,2
    • With the screws removed, gently remove the case from the internals.
  9. Kindle Touch Speaker Replacement, Speaker: 步骤 9 中的图像 1,3 Kindle Touch Speaker Replacement, Speaker: 步骤 9 中的图像 2,3 Kindle Touch Speaker Replacement, Speaker: 步骤 9 中的图像 3,3
    • Use the pointy end of your Spudger to separate the Speaker's connector from the motherboard on both sides.
  10. Kindle Touch Speaker Replacement: 步骤 10 中的图像 1,3 Kindle Touch Speaker Replacement: 步骤 10 中的图像 2,3 Kindle Touch Speaker Replacement: 步骤 10 中的图像 3,3
    • The speakers are held down solely with contact adhesive, so use your Spudger to pry them from the support board.
结论
Adam Yerly
于01/20/15注册
1,940 声望
创作了7篇指南
团队
USF Tampa, Team 19-5, Blackwell Winter 2015 USF Tampa, Team 19-5, Blackwell Winter 2015 的会员
USFT-BLACKWELL-W15S19G5
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 12
总计 1,089
