跳转到主内容
Kindle Touch 3G Card Housing Replacement
你所需要的
视频概述
  1. Kindle Touch 3G Card Housing Replacement, Back Cover: 步骤 1 中的图像 1,3 Kindle Touch 3G Card Housing Replacement, Back Cover: 步骤 1 中的图像 2,3 Kindle Touch 3G Card Housing Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Use the plastic opening tool to undo the six plastic clips around the bottom of the back panel of the Kindle.
    • Don't pry the clips on the top half of the back panel.
  2. Kindle Touch 3G Card Housing Replacement: 步骤 2 中的图像 1,2 Kindle Touch 3G Card Housing Replacement: 步骤 2 中的图像 2,2
    • Slide the back panel downward, toward the charging port. This will release the clips on the top half.
    • Once the top clips release, gently lift the back panel away.
  3. Kindle Touch 3G Card Housing Replacement, Battery: 步骤 3 中的图像 1,3 Kindle Touch 3G Card Housing Replacement, Battery: 步骤 3 中的图像 2,3 Kindle Touch 3G Card Housing Replacement, Battery: 步骤 3 中的图像 3,3
    • Use a Phillips #00 screwdriver to remove the five screws.
  4. Kindle Touch 3G Card Housing Replacement: 步骤 4 中的图像 1,3 Kindle Touch 3G Card Housing Replacement: 步骤 4 中的图像 2,3 Kindle Touch 3G Card Housing Replacement: 步骤 4 中的图像 3,3
    • Using the flat end of your spudger, gently pry the battery up and remove it.
  5. Kindle Touch 3G Card Housing Replacement, Remove the 3G Board: 步骤 5 中的图像 1,3 Kindle Touch 3G Card Housing Replacement, Remove the 3G Board: 步骤 5 中的图像 2,3 Kindle Touch 3G Card Housing Replacement, Remove the 3G Board: 步骤 5 中的图像 3,3
    • Remove the indicated four 2 mm screws with a Phillips #00 screwdriver. (Units with the 3G assembly have Phillips #000 screws.)
    • Next, gently lift the 3G assembly with a Spudger or your fingers.
    • This Kindle Touch is the WiFi only model and comes with a plastic placeholder instead of the 3G assembly.
    • Disconnect the antenna lead by carefully prying it off the 3G board with a plastic tool.
结论
3等其他人完成本指南。
Adam Yerly
于01/20/15注册
1,940 声望
创作了7篇指南
团队
USF Tampa, Team 19-5, Blackwell Winter 2015 USF Tampa, Team 19-5, Blackwell Winter 2015 的会员
USFT-BLACKWELL-W15S19G5
3 名成员
创作了8篇指南
2条评论
Hey, thanks for your guide!
I, however, have one question, maybe I misunderstood - is it possible to add a 3G module to a kindle touch that didn't have one installed by default?
Would it work?
Curious_Guy_Threepwood - 回复
You would need to add more than just a 3G module - there’s a slot for a SIM-card tray and special Amazon SIM that are missing from non-3G Kindle Touches. I don’t know if there would be any software changes that would need making.
Darren John de Lima -
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 21
总计 2,117
