跳转到主内容
加入维修社区 - 创建账户
Kindle Paperwhite 3rd Generation Motherboard Replacement
你所需要的
    1. Kindle Paperwhite 3rd Generation Motherboard Replacement, Battery: 步骤 1 中的图像 1,3 Kindle Paperwhite 3rd Generation Motherboard Replacement, Battery: 步骤 1 中的图像 2,3 Kindle Paperwhite 3rd Generation Motherboard Replacement, Battery: 步骤 1 中的图像 3,3
      • Ensure that the device is turned off before beginning.
      • Gently pry the bezel off the screen using a plastic opening tool. Start at the corners and slide around the edges until you return to your starting point.
      • Be careful if using the metal spudger, as it can scratch the surface of the Kindle.
      添加评论
    2. Kindle Paperwhite 3rd Generation Motherboard Replacement, Using caution: 步骤 2 中的图像 1,3 Kindle Paperwhite 3rd Generation Motherboard Replacement, Using caution: 步骤 2 中的图像 2,3 Kindle Paperwhite 3rd Generation Motherboard Replacement, Using caution: 步骤 2 中的图像 3,3
      • Use extreme caution when prying up the bezel. Be careful not to allow your pry tool to fall underneath the display. Look under the cover as you work, separating the display from the adhesive of the bezel.
      • You want to make sure your separator goes through both sides of the bezel over top of the display.
      • The second photo is the layer you want your tool to pass through safely.
      • The third photo is an example of what can go wrong. If this happens your digitizer layer will misread touches and the display is permanently damaged.
      添加评论
    3. Kindle Paperwhite 3rd Generation Motherboard Replacement: 步骤 3 中的图像 1,2 Kindle Paperwhite 3rd Generation Motherboard Replacement: 步骤 3 中的图像 2,2
      • Unscrew the eleven 3.2 mm Phillips #000 screws surrounding the frame.
      添加评论
    4. Kindle Paperwhite 3rd Generation Motherboard Replacement: 步骤 4 中的图像 1,1
      • Gently lift the mid-frame out of the case with your hands.
      • Lift the side opposite of the power button out first.
      添加评论
    5. Kindle Paperwhite 3rd Generation Motherboard Replacement: 步骤 5 中的图像 1,2 Kindle Paperwhite 3rd Generation Motherboard Replacement: 步骤 5 中的图像 2,2
      • Unscrew the three 3.0 mm Phillips #000 screws that are securing the battery.
      询问修复机器人
      添加评论
    6. Kindle Paperwhite 3rd Generation Motherboard Replacement: 步骤 6 中的图像 1,1
      • Gently lift the battery from the frame.
      添加评论
    1. Kindle Paperwhite 3rd Generation Motherboard Replacement, Motherboard: 步骤 7 中的图像 1,1
      • Flip the black latch with a plastic opening tool, and then gently pull back the orange ribbon cable.
      询问修复机器人
      添加评论
    2. Kindle Paperwhite 3rd Generation Motherboard Replacement: 步骤 8 中的图像 1,1
      在这个步骤中使用的工具:
      • Flip the tiny off-white latch with angled precision tweezers toward the direction of the battery.
      • Gently peel back the orange ribbon cable.
      询问修复机器人
      添加评论
    3. Kindle Paperwhite 3rd Generation Motherboard Replacement: 步骤 9 中的图像 1,2 Kindle Paperwhite 3rd Generation Motherboard Replacement: 步骤 9 中的图像 2,2
      • Peel back the orange ribbon cable near the battery.
      • Flip the tiny black latch with angled precision tweezers toward the closest edge of the device.
      询问修复机器人
      添加评论
    4. Kindle Paperwhite 3rd Generation Motherboard Replacement: 步骤 10 中的图像 1,1
      • Peel back the white connector with your fingers.
      询问修复机器人
      添加评论
    5. Kindle Paperwhite 3rd Generation Motherboard Replacement: 步骤 11 中的图像 1,2 Kindle Paperwhite 3rd Generation Motherboard Replacement: 步骤 11 中的图像 2,2
      • Unscrew the six 3.0 mm Phillips #000 screws surrounding the motherboard.
      • Unscrew the one 2.5 mm Phillips #000 screw.
      • There is a little metal plate underneath the 2.5 mm screw and washers under four of the 3.0 mm screws.
      询问修复机器人
      添加评论
    6. Kindle Paperwhite 3rd Generation Motherboard Replacement: 步骤 12 中的图像 1,1
      • Use a plastic opening tool to lift the motherboard upwards from the frame.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
13等其他人完成本指南。
Micah Smart
于02/10/16注册
3,428 声望
创作了3篇指南
团队
USF Tampa, Team 14-3, Lacy Spring 2016 USF Tampa, Team 14-3, Lacy Spring 2016 的会员
USFT-LACY-S16S14G3
4 名成员
创作了14篇指南
6指南评论
how do I fix my loose charging port?
angusc - 回复 分享
how do i fix my loose charging port connection
angusc - 回复 分享
Where can I buy a kindle paper white, new mother board?
Lorraine - 回复 分享
Tip, heat the front bezel to soften the glue.
KAASKOP3000 - 回复 分享
I totally know how to fix my kindle but I don’t know where to get the part. I broke the tip to the ribbon cable for the only %#*@ button on the device. do they sell those here?
Corry Newton - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 55
过去 30 天: 165
总计 15,457
