跳转到主内容
Kindle Paperwhite 3rd Generation Battery Replacement
你所需要的
  1. Kindle Paperwhite 3rd Generation Battery Replacement, Battery: 步骤 1 中的图像 1,3 Kindle Paperwhite 3rd Generation Battery Replacement, Battery: 步骤 1 中的图像 2,3 Kindle Paperwhite 3rd Generation Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Ensure that the device is turned off before beginning.
    • Gently pry the bezel off the screen using a plastic opening tool. Start at the corners and slide around the edges until you return to your starting point.
    • Be careful if using the metal spudger, as it can scratch the surface of the Kindle.
  2. Kindle Paperwhite 3rd Generation Battery Replacement, Using caution: 步骤 2 中的图像 1,3 Kindle Paperwhite 3rd Generation Battery Replacement, Using caution: 步骤 2 中的图像 2,3 Kindle Paperwhite 3rd Generation Battery Replacement, Using caution: 步骤 2 中的图像 3,3
    • Use extreme caution when prying up the bezel. Be careful not to allow your pry tool to fall underneath the display. Look under the cover as you work, separating the display from the adhesive of the bezel.
    • You want to make sure your separator goes through both sides of the bezel over top of the display.
    • The second photo is the layer you want your tool to pass through safely.
    • The third photo is an example of what can go wrong. If this happens your digitizer layer will misread touches and the display is permanently damaged.
  3. Kindle Paperwhite 3rd Generation Battery Replacement: 步骤 3 中的图像 1,2 Kindle Paperwhite 3rd Generation Battery Replacement: 步骤 3 中的图像 2,2
    • Unscrew the eleven 3.2 mm Phillips #000 screws surrounding the frame.
  4. Kindle Paperwhite 3rd Generation Battery Replacement: 步骤 4 中的图像 1,1
    • Gently lift the mid-frame out of the case with your hands.
    • Lift the side opposite of the power button out first.
  5. Kindle Paperwhite 3rd Generation Battery Replacement: 步骤 5 中的图像 1,2 Kindle Paperwhite 3rd Generation Battery Replacement: 步骤 5 中的图像 2,2
    • Unscrew the three 3.0 mm Phillips #000 screws that are securing the battery.
  6. Kindle Paperwhite 3rd Generation Battery Replacement: 步骤 6 中的图像 1,1
    • Gently lift the battery from the frame.
结论
76等其他人完成本指南。
Micah Smart
于02/10/16注册
3,116 声望
创作了3篇指南
团队
USF Tampa, Team 14-3, Lacy Spring 2016 USF Tampa, Team 14-3, Lacy Spring 2016 的会员
USFT-LACY-S16S14G3
4 名成员
创作了9篇指南
19条评论
Same for 5th Generation ??
PAUL FRIEND - 回复
where can i buy a new battery ?
david horn - 回复
you need a taobao.
lol
kassadin -
They are sold on aliexpress and ebay but the price of battery and postage is not that different from the price of a second hand 3ed Gen Kindle. But then the second hand Kindle will probably need a new battery too so, I am going to get a battery from ebay.
Timothy Takemoto -
添加评论
浏览统计数据:
过去 24 小时: 30
过去 7 天: 287
过去 30 天: 1,215
总计 72,421
