简介
Disassembling a tablet often requires some gentle prying of the frame. Be sure to exercise care during these first few steps(disassembling), and do not lose your screws! The Paperwhite is a sturdy tablet that can be broken down into just a few components. This guide will show you in just five short steps how to replace a faulty battery.
你所需要的
Insert plastic opening tool into the corners of the Paperwhite and slide around the edge perimeter to remove bezel.
31等其他人完成本指南。
7指南评论
Do you have a source for the battery itself? Thank you.
I’ve done this on two different Kindles with the same result: dead kindle. No matter how long it stays on the charger, the light stays amber. Screen will not change. Hard reset seems to do nothing; the light flashes, but no change. One Paperwhite even got a new motherboard. This is crazy! Is it possible to fix one, do I have to just buy another!?
Adam Britt - 回复
I'm probably 7 years too late but this was the case with one I got from Goodwill and plugging it into a higher amperage charger (2.4A) seemed to do the trick. When you plug it in it charges until there is enough power for it to boot up and when that happens it ends up draining the little bit that was there so it just gets stuck in a loop. You just have to give it more power to work with.
Hi Adam,
I have the same issue, the light is orange but the Kindle won’t turn on. I ordered the battery at www.batteryupgrade.com. But they have some misleading info on their website so they sent me the wrong battery even if it states that it supports Kindle Paperwhite 2012. Check the connections on original and on the new battery. In my case the battery looks the same, but the connections doesn’t. Now I’m waiting for the new one …
Regards.
Did replacement of battery help you to resolve problem?
