跳转到主内容
Kindle Paperwhite 1st Generation Case Replacement
你所需要的
  1. Kindle Paperwhite 1st Generation Case Replacement, Case: 步骤 1 中的图像 1,2 Kindle Paperwhite 1st Generation Case Replacement, Case: 步骤 1 中的图像 2,2
    • Using a spudger or plastic opening tool, gently pry the bezel from the screen. It is easier to start in the corners and work your way around the bezel.
    • Do not insert the spudger too far under the bezel; it could easily damage the screen.
    I found it easier to start this step off with one of the Opening Picks found in the iOpener pack.
    NathanF - 回复
    The glue on bezel started to peel the sticky back protective layer off the screen for me - managed to smooth it back down, although now have an unsightly crease. I would try to hold the screen down when you pull the bezel off to stop damaging the screen.
    Callum Rogers - 回复
    This step is most time consuming. Take you time and try not to scratch the bezel :)
    Oleksii - 回复
    Couldn't get the plastic spudger under the edge of the bezel. A right-angle X-Acto blade was a satisfactory tool here.
    dbrick - 回复
    The glue was VERY difficult...I used a trick, from taking apart phones, and used a hair drier to loosen up the glue...worked like a charm.
    billkaris - 回复
  2. Kindle Paperwhite 1st Generation Case Replacement: 步骤 2 中的图像 1,3 Kindle Paperwhite 1st Generation Case Replacement: 步骤 2 中的图像 2,3 Kindle Paperwhite 1st Generation Case Replacement: 步骤 2 中的图像 3,3
    • Remove the eleven 3.0 mm Phillips screws surrounding the midframe.
    • At the top of the display, a strip of black tape covers one screw.
    On 3G version you will not have the top middle screw.
    BJones - 回复
    Hello, the original battery is 1420m Ah and 3.7VDC, but the buttery you offer to sell is 1600mAh, is it right? there is no problem with different mAh? mi kindle is the amazon kindle 1est generation
    Paula Ponce de Leon - 回复
  3. Kindle Paperwhite 1st Generation Case Replacement: 步骤 3 中的图像 1,1
    • Lift the midframe out of the case.
    • If the midframe is stuck, slide it to the left first, and then lift it out.
    There are clips in the bottom of the case helping hold the midframe in. Lift the top of the midframe up enough to clear the black back piece and then slide up and out.
    BJones - 回复
结论
2等其他人完成本指南。
团队
Cal Poly, Team 3-33, Amido Winter 2013 Cal Poly, Team 3-33, Amido Winter 2013 的会员
CPSU-AMIDO-W13S3G33
4 名成员
创作了17篇指南
2条评论
Thanks for the guide but do you know anywhere can we get a replacement case?
jerryw - 回复
4 years too late but I found this
Pao-Tang Kao - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 73
总计 9,151
