简介
The case of your Kindle Paperwhite gets a lot of abuse from everyday life. Replace a cracked or a scratched case to restore that fresh out-of-the-box feeling.
你所需要的
Remove the eleven 3.0 mm Phillips screws surrounding the midframe.
Hello, the original battery is 1420m Ah and 3.7VDC, but the buttery you offer to sell is 1600mAh, is it right? there is no problem with different mAh? mi kindle is the amazon kindle 1est generation
2等其他人完成本指南。
I found it easier to start this step off with one of the Opening Picks found in the iOpener pack.
NathanF - 回复
The glue on bezel started to peel the sticky back protective layer off the screen for me - managed to smooth it back down, although now have an unsightly crease. I would try to hold the screen down when you pull the bezel off to stop damaging the screen.
Callum Rogers - 回复
This step is most time consuming. Take you time and try not to scratch the bezel :)
Oleksii - 回复
Couldn't get the plastic spudger under the edge of the bezel. A right-angle X-Acto blade was a satisfactory tool here.
dbrick - 回复
The glue was VERY difficult...I used a trick, from taking apart phones, and used a hair drier to loosen up the glue...worked like a charm.
billkaris - 回复
