跳转到主内容
加入维修社区 - 创建账户
Kindle Paperwhite 12th Gen Power Button Replacement
你所需要的
  1. Kindle Paperwhite 12th Gen Power Button Replacement, Bottom Case: 步骤 1 中的图像 1,2 Kindle Paperwhite 12th Gen Power Button Replacement, Bottom Case: 步骤 1 中的图像 2,2
    • Use an opening tool or opening picks and insert the tip between the back case and screen.
    • Slide the opening tool around the edge of the tablet to release the clips holding them together and avoid damaging the connectors.
    • You can also place additional opening picks in the space between the top and bottom case to prevent the front and back cases from snapping back together.
  2. Kindle Paperwhite 12th Gen Power Button Replacement: 步骤 2 中的图像 1,2 Kindle Paperwhite 12th Gen Power Button Replacement: 步骤 2 中的图像 2,2
    • Flip the Kindle over and remove back casing from screen and device.
    • When reassembling, align the top and bottom case and press until they click into place.
  3. Kindle Paperwhite 12th Gen Power Button Replacement, Power button: 步骤 3 中的图像 1,3 Kindle Paperwhite 12th Gen Power Button Replacement, Power button: 步骤 3 中的图像 2,3 Kindle Paperwhite 12th Gen Power Button Replacement, Power button: 步骤 3 中的图像 3,3
    • Use tweezers or your fingers to release the clips on each side of the button, gently lifting one side at a time.
    • The button housing is located at the bottom left of the charging port.
结论
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 36
总计 323
