跳转到主内容
加入维修社区 - 创建账户
Kindle PW2 fix screen scratch (replace screen surface layer/ light guide Replacement)
你所需要的
    1. Kindle PW2 fix screen scratch (replace screen surface layer/ light guide Replacement), TLDR: 步骤 1 中的图像 1,1
      • To save your time, yes the screen surface layer, or officially named light guide, can be easily peeled off.
      • Don't worry, it will not damage the touch screen and will not affect the touch sensitivity.
      • Then you can crop any common anti-glare PET screen protector into suitable size to replace the light guide
      询问修复机器人
      添加评论
    2. Kindle PW2 fix screen scratch (replace screen surface layer/ light guide Replacement), Uncover the frame: 步骤 2 中的图像 1,2 Kindle PW2 fix screen scratch (replace screen surface layer/ light guide Replacement), Uncover the frame: 步骤 2 中的图像 2,2
      • Actual guide starts from here, first uncover the frame. You may refer to other Kindle disassembly guide if you want more detailed steps.
      询问修复机器人
      添加评论
    3. Kindle PW2 fix screen scratch (replace screen surface layer/ light guide Replacement), Peel off the light guide: 步骤 3 中的图像 1,3 Kindle PW2 fix screen scratch (replace screen surface layer/ light guide Replacement), Peel off the light guide: 步骤 3 中的图像 2,3 Kindle PW2 fix screen scratch (replace screen surface layer/ light guide Replacement), Peel off the light guide: 步骤 3 中的图像 3,3
      • Start to peel off from any of the 4 corners. Just be careful not to scratch the touch screen, which is the glossy surface under this plastic light guide.
      • *Feedback from other fixers: suggest to peel from the top corner, as the bottom corner is close to the backlight and it can be accidentally damaged.
      询问修复机器人
      添加评论
    4. Kindle PW2 fix screen scratch (replace screen surface layer/ light guide Replacement), The nanomiprinted anti-glare light: 步骤 4 中的图像 1,3 Kindle PW2 fix screen scratch (replace screen surface layer/ light guide Replacement), The nanomiprinted anti-glare light: 步骤 4 中的图像 2,3 Kindle PW2 fix screen scratch (replace screen surface layer/ light guide Replacement), The nanomiprinted anti-glare light: 步骤 4 中的图像 3,3
      • This is the peeled off light guide. which is an anti-glare layer.
      • It has a thin sticky layer at the back to stick to the touch screen
      询问修复机器人
      添加评论
    5. Kindle PW2 fix screen scratch (replace screen surface layer/ light guide Replacement), replace with an anti-glare screen protector: 步骤 5 中的图像 1,2 Kindle PW2 fix screen scratch (replace screen surface layer/ light guide Replacement), replace with an anti-glare screen protector: 步骤 5 中的图像 2,2
      • After peeling off the original light guide, replace with any common anti-glare PET screen protector
      • You may get a matt screen guard designed for kindle. But this one I got lower the resolution of the screen, i.e. the text became less clear.
      • I then tried another anti-glare iPad PET screen protector. Cut it into Kindle's size. This one does not lower the resolution, but the anti-glare effect is not as good as the original light guide.
      询问修复机器人
      添加评论
    6. Kindle PW2 fix screen scratch (replace screen surface layer/ light guide Replacement), Compare to original light guide: 步骤 6 中的图像 1,1
      • Refer to the image, the left is a PW with original light guide and the right is the one with iPad protector
      • The anti-glare-ness is not as good as before but at least the annoying scratches are gone. If you found any good anti-glare screen protector that is as good as the original nanoiprinted light guide. Please share with everyone.
      询问修复机器人
      添加评论
结论
To fix a PW with scratched display in a low cost. Instead of replacing the whole integrated screen part, we can replace the light guide with an anti-glare PET screen protector.
取消:我没有完成这个指南。
2等其他人完成本指南。
potechto
于12/11/22注册
307 声望
创作了2篇指南
22指南评论
Does the light work with the non original light guide layer?
Cyberman - 回复 分享
Yes the backlight will still work, 100%, no worries.
potechto - 回复 分享
Also thank you very much for the guide
Cyberman - 回复 分享
Thank you, fingers crossed, will try. I’ve managed to get these deep scratches on 2 kindles.
Cyberman - 回复 分享
Good luck! Feel free to share with us your fixing experience
potechto - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 64
过去 30 天: 225
总计 9,716
