跳转到主内容
Kindle Fire HD Front Facing Camera Replacement
你所需要的
  1. Kindle Fire HD Front Facing Camera Replacement, Open the Kindle: 步骤 1 中的图像 1,3 Kindle Fire HD Front Facing Camera Replacement, Open the Kindle: 步骤 1 中的图像 2,3 Kindle Fire HD Front Facing Camera Replacement, Open the Kindle: 步骤 1 中的图像 3,3
    • Wedge a plastic opening tool into the lower right corner of the Kindle Fire.
    • Lift up until you hear a slight popping noise.
    • Repeat along the perimeter of the device to release the clips securing the case halves to each other. Remove the back cover.
    • The Kindle Fire could possibly have tape on the inside. Check for tape before removing the back cover.
  2. Kindle Fire HD Front Facing Camera Replacement: 步骤 2 中的图像 1,1
    • If your device has copper tape attached to the battery, carefully peel it off the battery.
  3. Kindle Fire HD Front Facing Camera Replacement: 步骤 3 中的图像 1,2 Kindle Fire HD Front Facing Camera Replacement: 步骤 3 中的图像 2,2
    • Locate the antenna cable connector which is easier to find if you look for the gold tipped black wire that surrounds the battery.
    • Lift and pull up the antenna connector and the antenna cable that surrounds the battery
  4. Kindle Fire HD Front Facing Camera Replacement, Remove Screws: 步骤 4 中的图像 1,3 Kindle Fire HD Front Facing Camera Replacement, Remove Screws: 步骤 4 中的图像 2,3 Kindle Fire HD Front Facing Camera Replacement, Remove Screws: 步骤 4 中的图像 3,3
    • Locate and unscrew the four 3 mm screws using the Phillips #00 screwdriver.
    • Unscrew the one T5 Torx screw using the special T5 Torx screwdriver head.
    • The 2 mm T5 Torx screw is located on the motherboard near the antenna clip.
    • If you aren't equipped with the T5 Torx screwdriver, you could try using your fingers, although it will be very difficult to remove it.
  5. Kindle Fire HD Front Facing Camera Replacement, Detach Cable: 步骤 5 中的图像 1,2 Kindle Fire HD Front Facing Camera Replacement, Detach Cable: 步骤 5 中的图像 2,2
    • Detach the plastic piece that connects the wires to the motherboard using the plastic opening tool.
  6. Kindle Fire HD Front Facing Camera Replacement: 步骤 6 中的图像 1,1
    • Lift the battery out of the device with your finger or the plastic opening tool.
  7. Kindle Fire HD Front Facing Camera Replacement, Front Facing Camera: 步骤 7 中的图像 1,2 Kindle Fire HD Front Facing Camera Replacement, Front Facing Camera: 步骤 7 中的图像 2,2
    • After removing the battery, locate the camera.
  8. Kindle Fire HD Front Facing Camera Replacement: 步骤 8 中的图像 1,2 Kindle Fire HD Front Facing Camera Replacement: 步骤 8 中的图像 2,2
    • Use the plastic opening tool to carefully lift the camera up.
    • Now you may lift the camera out of your device.
结论
2等其他人完成本指南。
Matthew Hodgdon
于03/03/15注册
1,366 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 1,426
