跳转到主内容
Kindle Fire HD 8.9" Charger & Micro HDMI Input Replacement
你所需要的
  1. Kindle Fire HD 8.9" Charger & Micro HDMI Input Replacement, Screen: 步骤 1 中的图像 1,3 Kindle Fire HD 8.9" Charger & Micro HDMI Input Replacement, Screen: 步骤 1 中的图像 2,3 Kindle Fire HD 8.9" Charger & Micro HDMI Input Replacement, Screen: 步骤 1 中的图像 3,3
    • Insert a large plastic opening tool next to the Kindle's headphone jack.
    • Make sure the notch on the plastic opening tool is facing the back of the Kindle.
    • Move the plastic opening tool evenly around the Kindle, separating the two halves.
    • Be careful not to completely separate the rear cover. There are two delicate flex cables that connect the display assembly to the motherboard.
  2. Kindle Fire HD 8.9" Charger & Micro HDMI Input Replacement: 步骤 2 中的图像 1,1
    • Set the Kindle down on the rear case.
    • Holding the display assembly near the camera, carefully open the display assembly up to about 90 degrees from the rear case.
    • These images show the Kindle laying flat. In order to prevent damage to the flex cables, keep the Kindle open at 90 degrees while disconnecting the display assembly.
  3. Kindle Fire HD 8.9" Charger & Micro HDMI Input Replacement: 步骤 3 中的图像 1,3 Kindle Fire HD 8.9" Charger & Micro HDMI Input Replacement: 步骤 3 中的图像 2,3 Kindle Fire HD 8.9" Charger & Micro HDMI Input Replacement: 步骤 3 中的图像 3,3
    • Lift the retaining flap on the ZIF connector of the upper flex cable.
    • Gently pull the cable out of its socket.
    • This flex cable is delicate. Be careful not to crease or bend it while working.
  4. Kindle Fire HD 8.9" Charger & Micro HDMI Input Replacement: 步骤 4 中的图像 1,1
    • Separate the display assembly from the rest of the device.
    • When reassembling the device, align the two halves of the case before connecting the flex cables.
  5. Kindle Fire HD 8.9" Charger & Micro HDMI Input Replacement, Inner Metal Casing: 步骤 5 中的图像 1,2 Kindle Fire HD 8.9" Charger & Micro HDMI Input Replacement, Inner Metal Casing: 步骤 5 中的图像 2,2
    • Remove the following sixteen screws from the metal midframe on the rear of the device:
    • Four 3 mm Phillips screw (located in each corner of the device - noted in red in the diagram)
    • Four 3 mm Phillips screws (surrounding the ports - noted in orange in the diagram)
    • Eight 3 mm Phillips screws (located around the body of the midframe - noted in yellow in the diagram)
  6. Kindle Fire HD 8.9" Charger & Micro HDMI Input Replacement: 步骤 6 中的图像 1,2 Kindle Fire HD 8.9" Charger & Micro HDMI Input Replacement: 步骤 6 中的图像 2,2
    • Carefully remove the metal midframe.
  7. Kindle Fire HD 8.9" Charger & Micro HDMI Input Replacement, Charger & Micro HDMI Input: 步骤 7 中的图像 1,3 Kindle Fire HD 8.9" Charger & Micro HDMI Input Replacement, Charger & Micro HDMI Input: 步骤 7 中的图像 2,3 Kindle Fire HD 8.9" Charger & Micro HDMI Input Replacement, Charger & Micro HDMI Input: 步骤 7 中的图像 3,3
    • Locate the charger and micro HDMI input located on the back side of your Kindle.
    • Use your finger to gently apply pressure and push upward on the metal strip that faces the center of the Kindle.
    • Be careful to not bend the black portion that connects the two inputs when removing the metal strip.
    • Lift the metal strip on both sides by using your fingers.
  8. Kindle Fire HD 8.9" Charger & Micro HDMI Input Replacement: 步骤 8 中的图像 1,1
    • You have now successfully removed the charger and micro HDMI input.
结论
18等其他人完成本指南。
Joel Wilcox
于01/11/13注册
524 声望
撰写一个指南
团队
Cal Poly, Team 5-16, Forte Winter 2013 Cal Poly, Team 5-16, Forte Winter 2013 的会员
CPSU-FORTE-W13S5G16
5 名成员
创作了14篇指南
9指南评论
Where can I purchase the Charger and Micro HDMI input replacement part for my Kindle Fire HD 8.9 tablet?
greggbaxter - 回复
If you search Google for "Amazon Kindle Fire HD 8.9" Dock Assembly" a few will show up.
Shawn Allen - 回复
ebay is going to have the most options for any phone tablet etc parts. Look for your model number (general tip) do not just look for as a example samsung s3 mini glass there are variants based on carrier. So make sure your buying a kindle fire 8.9 and not a hdx part. I think in the 8.9 hds there are 2 variants i know there are 2 storage configs. So make sure you get the right part.
First link on ebay search kindle fire hd 8.9 hdmi port (has both ports) http://www.ebay.com/itm/Kindle-fire-HD-8... 25 bucks (note i have not used this seller previously and do not in any way support him/her or say to not buy from him/her This is only a example link showing average cost) This likely is not the best deal it is 28 ship with the 3 shipping tacked on.
Nova Flare - 回复
I'm all finished, I had a real problem figuring out the lock key. Now that I am all finished though the touchscreen is unresponsive. What the heck could I have done? I found this quite simple. And what the heck can I do to fix it? Any help would be awesome. Thanks!
Aimee Gordon - 回复
Same issue here...
mikebrownson -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 36
总计 26,815
