跳转到主内容
Kindle Fire HD 6 Speaker Replacement
你所需要的
  1. Kindle Fire HD 6 Speaker Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Place the device face down on a clean cloth or another smooth surface.
    • In the following steps, you will need to apply some force to your device. If your device is on a rough surface, you may scratch the screen.
    • Insert the plastic opening tool between the device’s front and back panels. You might need to wiggle the tool up and down to wedge it in the gap.
    • Maneuver the tool around the device until the back unclips from the front panel.
  2. Kindle Fire HD 6 Speaker Replacement: 步骤 2 中的图像 1,2 Kindle Fire HD 6 Speaker Replacement: 步骤 2 中的图像 2,2
    • Carefully separate the back panel from the rest of the device internals.
  3. Kindle Fire HD 6 Speaker Replacement, Speaker: 步骤 3 中的图像 1,1
    • Unscrew the two 3.5mm T5 Torx screws at the base of the speaker.
  4. Kindle Fire HD 6 Speaker Replacement: 步骤 4 中的图像 1,2 Kindle Fire HD 6 Speaker Replacement: 步骤 4 中的图像 2,2
    • Unclip the speaker wire that runs up the side of the battery and clips into the motherboard next to the battery connector. Gently pull it straight up.
  5. Kindle Fire HD 6 Speaker Replacement: 步骤 5 中的图像 1,2 Kindle Fire HD 6 Speaker Replacement: 步骤 5 中的图像 2,2
    • Lift the speaker out of the device.
结论
2等其他人完成本指南。
Cassandra Beck
于01/13/15注册
885 声望
创作了5篇指南
团队
Cal Poly, Team 70-4, Forte Winter 2015 Cal Poly, Team 70-4, Forte Winter 2015 的会员
CPSU-FORTE-W15S70G4
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 671
