跳转到主内容
Kindle Fire HD 6 Rear Facing Camera Replacement
你所需要的
  1. Kindle Fire HD 6 Rear Facing Camera Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Place the device face down on a clean cloth or another smooth surface.
    • In the following steps, you will need to apply some force to your device. If your device is on a rough surface, you may scratch the screen.
    • Insert the plastic opening tool between the device’s front and back panels. You might need to wiggle the tool up and down to wedge it in the gap.
    • Maneuver the tool around the device until the back unclips from the front panel.
  2. Kindle Fire HD 6 Rear Facing Camera Replacement: 步骤 2 中的图像 1,2 Kindle Fire HD 6 Rear Facing Camera Replacement: 步骤 2 中的图像 2,2
    • Carefully separate the back panel from the rest of the device internals.
  3. Kindle Fire HD 6 Rear Facing Camera Replacement, Rear Facing Camera: 步骤 3 中的图像 1,1
    • Unscrew the two 3.5mm T5 Torx Screws from the top of the camera.
  4. Kindle Fire HD 6 Rear Facing Camera Replacement: 步骤 4 中的图像 1,3 Kindle Fire HD 6 Rear Facing Camera Replacement: 步骤 4 中的图像 2,3 Kindle Fire HD 6 Rear Facing Camera Replacement: 步骤 4 中的图像 3,3
    • Be careful not to damage the camera lens as you remove the camera.
    • Gently pull the camera up and out of the device. As you pull, unclip the black and white connector with orange tape by popping it off at its base.
结论
Cassandra Beck
于01/13/15注册
885 声望
创作了5篇指南
团队
Cal Poly, Team 70-4, Forte Winter 2015 Cal Poly, Team 70-4, Forte Winter 2015 的会员
CPSU-FORTE-W15S70G4
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 14
总计 894
